Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Treal Brass Caster C Hub gen8 v2
Old 01-07-2023, 04:52 PM   #1
Default Treal Brass Caster C Hub gen8 v2
Does anyone have an image or instructions how the shock is relocated? As the stock location will no longer work?
I’ve hit a bit of a road block.
The inner and outer portal housing install went fine but this is really hanging me up.
I have searched and cannot find any clear photos or instructions. I’m not good at technology though so sorry in advance.
Thanks for any help.
BigMike330 is offline   Reply With Quote
Old 01-07-2023, 06:28 PM   #2
Gold Star Baby!
Location: North to Alaska - go north, the rush is on....
Default Re: Treal Brass Caster C Hub gen8 v2
I had a similar issue when I went to the Redcat aluminum C-Hubs. Omce you go to the metal (brass, or aluminum) C-Hubs, it does not require the "double shear" mount. It screws to the C-Hub and I lowered the upper shock mount to compensate for the distance/position to the mount in the new C-Hub.
Post #33 where I noticed the problem and Post #38 when I moved the shock mounting position. No real good pictures of it though.
New Gen8 AXE Edition. Choices, choices, choices...
AK KRAWLER is offline   Reply With Quote
Treal Brass Caster C Hub gen8 v2 - Similar Threads
Treal Brass on my class 2 comp build JMHZ2401 Redcat Crawlers 0 01-26-2021 05:35 PM
Treal brass knuckles and covers installed and tested rcreview Axial Capra 3 07-06-2020 12:42 PM
TRX-4 C-Hub (Castor Block) Pipe Brass Bushings 3x4.95x4.5 Locked Up Traxxas TRX-4 0 07-03-2018 03:48 PM
TRX-4 C-Hub (Castor Block) Pipe Brass Bushings 3x4.95x4.5 Locked Up Locked Up RC 0 07-03-2018 03:43 PM
