Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > Scale Accessories
Like Tree13Likes
Thread: My Utility Trailer -
Old 12-30-2012, 08:58 AM   #1
Default My Utility Trailer -
Hello,
after a long time that no longer writing on the forum I decided to share with you my new creation.
Is a utility trailer that can be used with the scaler 1/10 and also with the wraith that is a little larger.
The project has been designed in a couple of days. the first was a prototype in styrene to verify measurements and joints. It was later realized laser cutting.
The trailer is made entirely of metal 2mm laser cut. The parts are fitted together and secured with small welds.
I made the axles for the wheels. have been made by an aluminum bar 30mm.
Harlok67 is offline   Reply With Quote
Old 12-30-2012, 09:06 AM   #2
Default Re: My Utility Trailer -
Once cut parts, 7 in all. I joined started to assemble the trailer.
The parts all fit together perfectly but for safety I decided to give some small welding point.
The fender are folded along the lines and then welded to the side plates
mounting the hubs of the wheels ..
Old 12-30-2012, 09:55 AM   #3
for the wheels I chose to use those from 1.9 to axial honcho. The trailer is designed for use in heavy-duty off-road, such as wheels better?
The tailgate should be removable. I thought of a system that comes straight from the watch. I made two snap pins.
Old 12-30-2012, 10:21 AM   #4
Now we mount the spare wheel on the frame.
I am thinking of use this space for a container or other tools.
Built in styrene diamond plate
I suggest you give?
Still missing the hitch, painting and some other finish, but the result looks good.
Old 12-30-2012, 10:33 AM   #5
Wishing I was in MOAB!
Agama's Avatar
That trailer looks really sweet!
Agama is online now   Reply With Quote
Old 12-31-2012, 04:42 PM   #6
Man that trailer is nice you did a great job designing this
SlammedMKV is offline   Reply With Quote
Old 12-31-2012, 04:48 PM   #7
Adilynsdad too!
braceysdad's Avatar
Very cool that is... nice work you did
braceysdad is offline   Reply With Quote
Old 01-02-2013, 03:01 PM   #8
Nice job
y2ktj is offline   Reply With Quote
Old 01-02-2013, 04:44 PM   #9
Wow your fabrication is top notch!
darkmanx is online now   Reply With Quote
Old 01-02-2013, 04:56 PM   #10
Kustom RC Accessories
Krawler Konceptz's Avatar
Awesome attention to detail just need mounts for lights.
Rob
Krawler Konceptz is online now   Reply With Quote
Old 01-02-2013, 06:38 PM   #11
niiiceeeeeeeee.......
adbradwell is offline   Reply With Quote
Old 01-03-2013, 11:45 AM   #12
THANK YOU to everyone for the compliments!
These days I added the towbar and I painted the chassis with a steel color to hide the welds.
As soon as possible I'll show you the other pictures.
Old 01-04-2013, 09:49 PM   #13
so are you lucky enough to have a laser at your disposal or did you have it cut by a vendor? that thing is SWEET!!
ky_ace is offline   Reply With Quote
Old 01-05-2013, 04:00 AM   #14
I have a friend who lives near, working on laser cutting machines.
I draw, design and pass to him the dxf for cutting.
He is not modeller!
Old 01-08-2013, 03:06 PM   #15
Work continues on my utility trailer.
Was painted with a color stainless steel.
Was added the towbar.
Were added to the butterfly bolts to the tailgate.
I'm trying to make the wooden panels.
Old 01-08-2013, 07:19 PM   #16
This thing is killer man! Great job
FORDROX97 is offline   Reply With Quote
Old 01-12-2013, 09:29 AM   #17
Ok! my trailer is finished!
Old 01-12-2013, 09:32 AM   #18
and now here he is with one of my scaler
Old 01-12-2013, 09:39 AM   #19
Old 01-12-2013, 09:51 AM   #20
In total have been employed:
- About 8 hours of drawing and design with a couple of paper models
- Two models of tailgate wrong, the third fortune was perfect.
- A wrong hub machined from solid, two correct
- 10 minutes, the time of laser cutting
- Stainless steel color spray
- 4 bearings tamiya
- 3 wheels Flat Iron proline and 3 wheels AXIAL
- Aluminum square bars
- Self-locking nut 3mm
- Bars 6 mm aluminum
- Washers, nuts and bolts 3mm
- Uniball 4mm
- Wood and glue Pattex
- About 45 hours of editing, design, drawing and various tests
- A finger sliced ​​with a knife
My Utility Trailer - - Similar Threads
1/10 Utility Trailer Snowmaninhell Scale Accessories 123 05-13-2013 12:13 AM
New custom utility trailer 4 my dingo royt82 1.9 Scale Rigs 6 08-22-2012 08:12 PM
UTAC Utility Trailer DORK VADER Scale Accessories 19 06-30-2012 09:56 AM
Warriorsimi's Bronco and Utility Trailer Shurp Scale Videos! 2 03-09-2011 11:48 AM
Does anone have a utility trailer that I can borrow??? Cruzin Illusion Colorado 2 05-19-2010 01:03 PM
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
