Go Back   RCCrawler Forums > Scale Rigs General Tech > Scale Accessories
Thread: Scale magazines and maps
Old 03-09-2014, 03:22 PM   #1
Default Scale magazines and maps
Found some books at the craft store that were the perfect size. I found some mag covers I liked online, scaled them down and used a bit of CA glue to attach.
For the maps I did the same. Found pics, scaled them down, printed on photo paper, and cut them out.
jamesbernatchez is offline   Reply With Quote
Old 03-09-2014, 04:51 PM   #2
Default Re: Scale magazines and maps
Turned put nice, but...Rambo would never need a map...
TrailSnail is offline   Reply With Quote
Old 07-25-2014, 02:43 PM   #3
They turned out nice, been trying to make some myself, but they all turn out blurry.
mcdader is offline   Reply With Quote
Old 07-29-2014, 04:41 PM   #4
What printer did you use? I just printed a bunch myself (just haven't cut them out yet) and found in my case a laser printer worked much better than my inkjet printer.
Sent from my Nexus 7 using Tapatalk
Knytemare is offline   Reply With Quote
Old 07-30-2014, 10:23 PM   #5
Nice work. Turned out great. I have tried to scale down pictures but they always are blurry. Did you use a particular software?
cmbscx10 is offline   Reply With Quote
Old 07-31-2014, 11:17 PM   #6
same problem I am having.
Old 08-30-2014, 10:13 PM   #7
There are numerous factors that can go into why a print would be blurry, first off the size of the image you used to start with, the DPI at which you create the image, what printer you use etc. I start with the largest image I can find first then scale it down in Photoshop. I also printed mines on a laser jet printer which also helped in the print quality. Hope that helps!
Old 09-02-2014, 09:06 AM   #8
Blurry issues are probably printer related. I use a laser printer @ 1200 dpi.
Use search tools in google & select "large" images. However, you don't need a super detailed image if you are taking it down to 10 scale magazine size.
you don't really need any special software if you aren't editing. Google, copy & paste into a word doc works fine. But access to a decent laser printer helps quite a bit.
DRW-FJ40 is offline   Reply With Quote
Scale magazines and maps - Similar Threads
NIRC Comp Spot Maps johnnyh66 Illinois 36 05-08-2020 03:31 PM
Crawling Maps Rockcrawler Alabama 15 10-31-2018 11:15 AM
Searching Google Maps pays off once again! ittybitty South Carolina 21 01-08-2011 10:09 AM
Maps to ABQ Comp #3 RAM2500 New Mexico 0 02-10-2009 03:21 PM
online maps? fordzilla1 Chit Chat 0 09-06-2007 10:29 PM
