10-29-2012, 01:37 PM | #1 |
| C3 jibber jabber
Since its hard not to talk about it, here's a thread to put the chit chat and whatnot without mucking up other more dedicated threads. FWIW: nobody is suggesting that AR60 axles should be outlawed. Builders just need to be mindful of their width when building. Since they are a more or less 1:8 scale parts, whatever is bolted on to them needs to be proportional. The term "outlaw" was used in suggestion of another class specifically for those who do not wish to maintain a more strict scale appearance and put performance first, the skinny bodies/cages, fat tires, and wide axled types. That will leave C3 more dedicated to the scale aspect without builders having to run against pseudo-comp rigs. The committee is sorting stuff out, but there is no reason why that the rest of us can't discuss it publicly if we keep it civil! |
10-29-2012, 01:49 PM | #2 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
| Re: C3 jibber jabber
Give up man, just move on. You have said more then enough for everyone and then some. Sorry if you take this as negitive but the good guys on the scale committee have it handled. I would suggest go building something to take up your time. Justin, |
10-29-2012, 02:07 PM | #3 |
Nope, not here to argue, just thought I'd make a thread to keep the talking out of the one for the pictures. If nobody wants it I'll make it go away...
10-29-2012, 06:51 PM | #4 |
I think that the Rules Committee has enough on their plate to discuss right now. I said a lot in the last thread, so until they come out with answers and new rules, I'm ready to keep quiet for awhile.
10-29-2012, 07:40 PM | #5 |
I agree, and really I just wanted to make sure that nobody thinks that those of us that raised the questions and pressed the issue were out to kill those rigs or those axles. |
10-30-2012, 08:40 AM | #6 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
I think there has been quite a bit of discussion on the topic, but I don't think it's done yet. To say that the rules committee has it handled and that we should all shut up until they come up with something is a bit asinine. The key points are: Many AR60 axle based rigs use bodies no wider than about 5-6". If that is scaled up to 1:1 (based on 1:8 scale) that makes the 6" body a 48" 1:1. That's the same width as a golf cart. If that doesn't put it into perspective, than nothing will. Those that use AX10 axles with a 1:10 scale body or those with a 1:8 scale body on AR60's should not be in the same competition class as the golf carts on steroids, just the same as those type of vehicles would not be in the same class in 1:1. There are some narrow body/wide axle 1:1's, such as single seater custom builds, and builders wanting to build something scale realistic can use AR60's, but should keep overall proportion in mind. Skewing the proportion for performance advantage is not what I would consider the spirit of building scale vehicles. There are many passionate people in the hobby that have their opinions, and some of them take these discussions personally, get offended, and fly off the handle. No one here (I think) is out to make current builders have to totally re-build or to exclude anyone or to pick on any one build. As long as the intention of the new rules is to encourage scale realistic proportional builds, then I am all for it. If the rules allow both types of rigs to compete in the same class, you WILL see a decline in scale realistic builds. We don't want disguised comp rigs, we want scale. |
10-30-2012, 11:07 AM | #7 |
Moderator Join Date: Jan 2004 Location: chicago
i'm eager to know what the solve is gonna be...
10-30-2012, 12:19 PM | #8 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
| Re: C3 jibber jabber |
10-30-2012, 12:24 PM | #9 |
I wanna be Dave Join Date: Dec 2008 Location: ?
10-30-2012, 12:27 PM | #10 |
10-30-2012, 12:29 PM | #11 |
10-30-2012, 01:30 PM | #12 |
10-30-2012, 06:02 PM | #13 |
So, the (read between the lines) suggestion is to base class on tire size and how much tire sticks out? Not a bad idea. Based on that: C1 - 4.19" Max tire, 1/2 Max tread exposed (Same as current) C2 - 4.75" max tire, inside of tread even with outside of body C3 - 5.5" max tire, inside of tread within 1/2" of overall body width. C3X - 5.75" max tire, no restriction on inside of tread compared to body. C3 and C3X run on same course, can only run one or the other class. ideas? |
10-30-2012, 06:05 PM | #14 |
I would tighten up C3 even more...say no more than 1/4" past the body. That still give you lots of build options.
10-30-2012, 06:38 PM | #15 | |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| Re: C3 jibber jabber Quote:
Great ideas guys, please keep giving input on other Class 3 items. | |
10-30-2012, 06:52 PM | #16 |
10-30-2012, 06:58 PM | #17 | |
Rock Crawler Join Date: Oct 2009 Location: Washington State
| Re: C3 jibber jabber X1,000% Well said sir. Quote:
10-30-2012, 07:56 PM | #18 |
I'm not so sure a certain width out solves anything, it's proportional to what body you run. A Toyota or Jeep should hang the tires out quite a bit in class three, a full size Chevy or Ford shouldn't though. Maybe outlaw Tamiya bodies, seems 90% or more of the sportsman trucks running class 3 use them. As it stands now the only options to be competitive in class 3 and truly look scale are buggies anyways.
10-30-2012, 08:40 PM | #19 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
10-30-2012, 09:53 PM | #20 | |
a lot of people worry that adding a new class would complicate comps, but if you split class 3, and only allow any one person to run in one or the other class, you don't add ANY time to events. if you don't have enough for two sub classes locally, then run them together and provide a deduction towards scale points for the new sub class. it really doesn't need to be hard to do. i have seen class 3 rigs that are scale beat out narrow buggy body rigs, but it is much easier to compete with an 'edge of the rules' rig. within the current rules, i could take a 5" wide 1/12 scale tj body, toss it on ar60's, Max out scale points, and i would have something that looks crazy, but fits the rules. i really don't think that's what we want. it's obvious that with the ar60 axles new types of rigs are possible. the rules just need to evolve to accommodate them in a way that keeps it fair, while encouraging scale realism. | |
