Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Loading
Thread: My Timber Wolf
Old 01-21-2009, 01:04 PM   #1
Default My Timber Wolf
Hi all,
Well I want to give a big Thanks to RPP Hobby for having everything I needed to build this bad boy.
I'll post up Spec's a little later as I'm still changing things around and adding more details.
But for starters here's what I got so far.
Thanks for Looking.
DB
DBmodels is offline   Reply With Quote
Old 01-21-2009, 01:06 PM   #2
That's is sweet
megacabcummins is offline   Reply With Quote
Old 01-21-2009, 01:23 PM   #3
Wow dude like your wolf with a bite.LOL!!! by the way i dont like yout sing i the picture it says, MOUNT GAY BARBEDOUSE BEER??? WTF!!!!
edward87 is offline   Reply With Quote
Old 01-25-2009, 04:47 PM   #4
Nice Wolf, I see you have screws in your side panels how did you mount them????????
gotmax59 is offline   Reply With Quote
Old 01-25-2009, 08:54 PM   #5
How did you end up mounting them HR shocks on the top?
Very nice rig.
2JSC is offline   Reply With Quote
Old 01-25-2009, 10:54 PM   #6
Thanks ......
gotmax59: I used 1/4" nylon p-clips , they work fine so far.
2JSC: I used the stock shock bosses that came with the shock, but I added a extra spacer that was the same dia as the shock boss allows the shock to slide a little more and keeps the shock from binding...
The back was easy it was the front that was a pain getting to work smooth.
Here's the pretty much finished wolf. I still need to pain a couple things and still need to add my air bottle.
Wheel base is at 13 Inches.
track is a tad under 10inches.
3 inches of g/c.
stock Axial axles.
Punisher shafts.
Axial gear box.
123mm double spring HR Shocks.
RPP limited edition 2.2 Alum/beadlocks.
Rock crusher X/T 2.2 tires
Rooster S/C.
Integy steering linkage.
Thats about it .....
Old 01-25-2009, 11:21 PM   #7
Quote:
Ah - See, not being able to mount mine vertical will cause some issues. Need to use some tubing or find a shock cap that will work that has a capture ball on it.
Thanks for the info though.
Old 01-26-2009, 10:00 PM   #8
RPP Hobby's Avatar
Wow man your rig turned out great
RPP Hobby is offline   Reply With Quote
Old 01-27-2009, 10:28 PM   #9
What kind of lights or light kit do you have, they look on your Wolf
Old 01-29-2009, 01:03 AM   #10
Well I lost my last reply .... and so , dam here it is agin shorter..
Broke the front bumper on it's 2nd run.
Rebuilt the front .
Mike was on this and he rocks !!!
We just went a new way and have a new crawler with a new look, we will be doing more to the front bumper but not yet...
I had my brother in - law work my wolf and I also took some pic's of his crawler so here's all the pic's.
Broken
Kida new fix
My bro's crawler ......
He builds real 1:1 Trophy Trucks...
Old 01-29-2009, 01:05 AM   #11
The lights . I got them from Rpp about a year ago. Contact them and they might be able to help you..
DB
Old 01-29-2009, 01:21 AM   #12
i love that jeep, its looks killer, great Job.
aaugman is offline   Reply With Quote
Old 01-29-2009, 02:00 AM   #13
dbmodels.
That you have used to fix the lateral panels?
mactech is offline   Reply With Quote
Old 01-29-2009, 08:00 PM   #14
I like the look of the fix better. The long stinger makes it look like you're compensating for something.
karlos is offline   Reply With Quote
Old 01-30-2009, 09:15 AM   #15
WoW Very nice Timber Wolf I like how you mounted
the spare tire
prusik333 is offline   Reply With Quote
You may not edit your posts
