Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Loading
Thread: SWAT Ford F150 09', New Bright body-Bruiser frame, Norcc build of comp entry.
Old 12-15-2009, 11:13 AM   #1
Default SWAT Ford F150 09', New Bright body-Bruiser frame. Now with comp pics...
Forgot I hadn't postet this build here.
My build started over @ scale4x4..
I got hold of a New Brigth Ford F150 body from Dale, thanx mate
Wild Trail delivered the body to me yesterday when I was on a trip to his town.
Thanx very much to you too Pål
Spec on the build.
New Brigth Ford F150 body.
Bruiser chassis with Chino skid.
Pede gearbox.
Leafed rear and coil in front.
TLT or HL axles..
Hope I can finish this build before the deadline this time
This rig was the trigger and inspiration for this build.
Pantablo buildt it first and the owner finished it afterwards. Sick rig
I have an idea how this build could look like when finished, but I will reval that later...
Bone stock body as I recivied it yesterday..
The body have got a smack in the roof under transport from over the pond, but it can be fixed.
I want to do the same as Pantablo did on the F150, that is to paint on the bedliner..
Most of the stock bodymounts will have to be removed.
It looks like it is enough space to put in some small LED's.
Pics of the Bruiser frame with Chino skid.
I think this is gonna be allrigth with some removal of the body posts.
Nice to have mirrors that can fold in
My hotgun was usefull to remove the decals....
The Dremel went for some work when I got some snack.
I missing the leaf hangers, shackles and some other bits so I have to get them, or make something myself...
Time will show if I can pull this through
Havn't build anything the last couple of days as I'm waiting for some suspension parts..
So not much to take pics of..
But I have been surfin the nett to find pictures of what I have in my head..
The rig will be 2 in 1.
The Theme is................................................ drums please
SWAT VEHICLE
Emty pick up is not that thrilling so I have to make som scale items.
I think I gonna make a ladder rack.
Something like this.
My plan is to make the legs to go down in the bed.
And since I'm not any good at bracing, this will be in styrene.
And there will be cargo boxes in the bed, the SWAT guys need space for their equipment
The rig will have flat black paint on the body, and white details as rock sliders, ladder rack etc...
Version 2 of same rig:
I have long been intrested to build a camper, so ver. 2 will have a detachable camper.
In my fantacy I think the SWAT team have to travel a long distance to deal with a long term hostage situation etc
I want to build a crossover of these campers:
The SWAT theme is very applicable as there is a very wide variation of vehicles to make.
You have small cars, armoured vehicles, airport rigs etc..
This is an ambulance
Got a few parts in the mailbox today so could build some more..
Made up some temporary links og mounted the leafs in the rear.
I realy want to get some Bruiser leaf mounts to get the rigth higth, but for time beeing, some Diaz leaf lift blocks have to do the job.
There will be 4 or 3 link in front of this rig because of the HL axles.
I wanted to use the Trail finder leaf mounts in front for the links, but the links was too short and the axle did some funny movments under suspensiion cycle up and down.
Nor did I want to drill more holes in the frame than there already was.
I solved the problem by using some TLT link mounts mounted rigth in front of the skid.
Top wiew.
Used some spacers to get the rigth distance for the leafs.
Dodn't want to make a braket between the leaf and the axle.
I also had to lengthen the frame a tiny bit to get the correct angle for the shackles.
The top front links are Y shaped, but I think I gonna swap it out for a 4 link system, due not freely enough movments.
Frame fit nice in the rear.
Some few mm change in the front suspension and it is good to go
I think the Bruisert frame fit this body really good.
If I had to swap the frame out, I would had gone for a MSD UTE 13" chassis.
For now this is just mock up, have to change a few links, but it's getting there.
Missing the last HL axle so I can test with the wheels on.
Do someone have some spare king pin collar for the HL axles???
I'm short by 4 pieces.
Soon a roller
I'm on low stock of things to build this rig from. I have to look into all my big and small part boxes to find screws, drive pins, hexes etc..
Must go and buy some parts soon
The pic is lying a bit, the tires stick a bit more than it apear, but not much.
From the side..
The tires sticks a bit more out in front, but just by an margin.
Side.
Changed for 4 link, much better now
This ambulance is on Norwegian ground rigth now, due the visit of Obama during the Nobel peace price award.
caprinut is offline   Reply With Quote
Old 12-15-2009, 11:19 AM   #2
Huston, we have a roller
In these re-use days I have used some of my old parts, the WK battery holder and I have robbed the tlt shocks from my Landy build just for the mock up.
Not much parts left in the Landy in the shelf these days
BTW, the shock towers are just temporary to messure the higth needed for the shocks.
A bit long I think the wb is 1 cm too long..
Flex with empty chassis, just the battery is on the chassis, much more flex left in the system.
Not easy to se on these pics, but can you see what I did???
If you guessed englared wheel arches, you are rigth
Did the Pantablo method...
Worked like a charm, thanx for the tip Pantablo
The suspension is not high enough compared to the body, so I have to get me some Bruiser parts later.
This is the higth I'm looking for.
Made up the rear body mounts, some temporary ones that is.
Too long wheelbase...hehe.
Nice fit with weigth or under flex
New Brigth F150+HL axles, Axial 1.9 wheels = Nice width
Tomorrow I gonna make the front body mounts, front shock tower and relocate the battery box a bit.
Perhaps some outside shots to get some better pics
Sorry for some of the blury pics, had to hold a spot ligth in one hand, and take pics with the other due my dark living room...
This is the stance rigth now, I really want the body to sit a few mm higher, and the frame to be lifted a half an inch...
My part pusher will order a Bruiser leaf mount kit later, that will lift the chassis about there I want it.
Front wheel now fit the wheel arch nicely after shortning the links a bit.
Same with the rears.
Fexin' all corners
My rear body mount system, these will be hidden by the tool boxes or the camper thingy..
My styrene shock towers
Overall look of the chassis
Rear body mounts, chassis side
My front temporary body mounts, thes clamps over the chassis on each side. Must see where the steering servo gonna be before I can make the final body mounts.
Took advance of the nice weather outside today and snapped some shots of it
Old 12-15-2009, 11:56 AM   #3
This is a sweet build! If it wasn't going to be a SWAT vehicle I'd say dovenose and bobbed bed.
SStone is offline   Reply With Quote
Old 12-15-2009, 12:12 PM   #4
Ha, I don't like dovenose og bobbed beds, so either way it had become a regular pick up truck of some sort
But thanks for the kind words
Old 12-15-2009, 12:25 PM   #5
Looks great so far. Looking forward to watching this build!
goldmember is offline   Reply With Quote
Old 12-15-2009, 12:31 PM   #6
~THE SCALE SHOP~
even though its a ford that is one sick build! LOVE the murdered out look!
STANG KILLA SS is offline   Reply With Quote
Old 12-15-2009, 01:13 PM   #7
x2 i agree with stang killa
chicostaxxs007 is offline   Reply With Quote
Old 12-15-2009, 02:17 PM   #8
Nice build, looking forward to seeing the rest of it
Ginky is offline   Reply With Quote
Old 12-17-2009, 10:29 AM   #9
The realism is incredible!
radio is offline   Reply With Quote
Old 12-17-2009, 11:00 AM   #10
That looks fantastic!! I saw that body in a toy store a few weeks back and it really got me thinking of how sweet of a scaler it would make, and now I can see exactly how sweet it is, just what I had envisioned! What is the tip for enlarging the wheel wells so cleanly?
kirex is offline   Reply With Quote
Old 12-17-2009, 01:52 PM   #11
Sinking with the ship
1BadJeepBruiser's Avatar
Looks good murdered out black, would make a good tow rig. Just loose the new bright sticker
Old 12-17-2009, 03:49 PM   #12
i like it i hope to see a vid when your done
1mopar is offline   Reply With Quote
Old 12-17-2009, 08:55 PM   #13
I saw one of thoes at TSC the other day. it looks awsome for a scaler
chris w is offline   Reply With Quote
Old 12-17-2009, 09:14 PM   #14
WOW, thanks for the post, I'v been wondering how the F150 would look as a scaler, and I was right, AWSOME, thanks again.
luv2ridemx is offline   Reply With Quote
Old 01-13-2010, 12:15 PM   #15
Thank folks
Post and copy from scale:
I have now made some front body posts with small magnets..
Seems to work great so far..
My temporearly servo mount, think I gonna make the finel one in styrene..
Low on founds latlley, or lack of founds is forcing me to make my own rear shocks..
Tlt parts and some ball ends..
And a short test video to see if the magnet body mounts is working, so far so good...
http://vimeo.com/8439446
Made 2 complete shocks..
Mock up..
Flex
The plan has allways been to remove the front bumper with more bad to the bone bumper.
I think I have found what I'm looking for, a good looking armored front bumper.
I will try to make it as close as I can of the picture, except I goona make it smoother, i.e no holes, just the hole for the lights and the fairlead.
After a visit at a friend of mine on the new year weekend, I realised the front body mounts was too weak.
So I came up with another system.
The system is a flat bar axross the mounts inside the body, with a pair of L brackets to center it.
On the chassis side there are a U profile that grips over the flat bar mounted on the body.
Very rigde, you can now lift the rig by the body front and rear.
I have a intercooler that is suposed to be fitted on a drifting car, I think of fitting this in front of the front body mounts.
Vinch is also comming on, it will be placed on the front xmember on the chassis, behind the body.
Now as my body mounts are in place, I can begin to make all the other stuff.
No more front bumper
Has started on the styrene front bumper..
Will laminate several layers of styrene to make the bumper.
Started with this
This is not a wing for a aeroplane with rocket launchers
This is the "rigth" side...
The beams will double as bumper brackets and the ears for the hook to hang on.
The tubes are for the fog lights..
Starting on the laminate prosess...
When all the gluing is finished, the file and sanding job starts...
The first layers of styrene...
Opned up the front xmember for the winch line.
The only place the winch fits good and will line up with the bumper is on the underside of the xmember.
Had to cut a bit out of the chassis where the motor in the winch are to get it centered.
The basic shape before filing and sanding..
When I got the basic shape I want, \________/ seen from abowe, I will add the other sheets of styrene to get the shape on top and under, like where I have drawn the red arrows on the picture.
Have to sand a bit more before I can add the other layers of styrene.
Made rock sliders this afternoon.
I used brake line and some 3mm all thread...
Old 01-13-2010, 12:26 PM   #16
nice for a ford. what size styrene did you use for your bumper?
Old 01-13-2010, 01:04 PM   #17
Thanx
I used 1.5mm or 0.60 sheet...
Old 01-13-2010, 01:54 PM   #18
i have been meaning to ask someone
how do those tires do in mud and on the rocks i want some but they look like they arent that good
93 FORD BRONCO is offline   Reply With Quote
Old 01-13-2010, 03:11 PM   #19
these tires do pretty well for me. they grip well on rocks, exept when they're wet. haven't tested them in mud yet. http://www.youtube.com/watch?v=PZBoDEMcsh8
sick truck btw
king_crawl22 is offline   Reply With Quote
Old 01-15-2010, 10:16 AM   #20
samn.
this thing is legit.
Nick Slemp is offline   Reply With Quote
You may not edit your posts
