Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > SSD Trail King - Pro Scale Chassis Builder Kit
Thread: Incision Universals Pro44 Compatibility
Old 05-27-2021, 08:50 AM   #1
Slow is the new Fast
smog's Avatar
Default Incision Universals Pro44 Compatibility
I broke a vvd on my Pro44. It was built from a Pro44 complete front axle kit. My local hobby shop does not carry SSD and I need a quick replacement. Is there any issue with running the Incision Universals, IRC00180 or the Axial Uni's in the Pro44? I can get both locally
smog is offline   Reply With Quote
Old 05-27-2021, 12:10 PM   #2
Gold Star Baby!
Topher Builds's Avatar
Default Re: Incision Universals Pro44 Compatibility
If that’s a trail king front axle then I do not think they will work as the short side on the vanquish and ar45s is a bit shorter than the short side of the trail king axle.
If it’s just a normal center pumpkin pro44 the you can use any of the AR44 based unis
Topher Builds is offline   Reply With Quote
Old 05-27-2021, 02:39 PM   #3
smog's Avatar
Thanks Topher, that is what i was looking for. Axle is not out of the TK kit, built it from the Pro44 complete front axle kit. The pumpkins are centered. I figured any universal for the AR44 would likely fit, it only makes sense. Just wanted to be sure there weren't any quirky incompatibilities.
Old 06-07-2021, 09:06 AM   #4
This may be neither here nor there, but I bought a set of Incision universals for the AR44 thinking they would fit in the Element Enduro axle as I read that there is cross-compatibility there. The Incisions bind in that axle and won't work. Smog, it seems you are an Element guy....what do you know about that? And what is a good upgrade for the Element universals when replacement time comes?
Thanks
borlo is offline   Reply With Quote
Old 06-07-2021, 10:37 AM   #5
smog's Avatar
Thanks
I haven't actually broken any axles on my Enduro kits so haven't had to replace any yet. Sadly, incision/vanquish isn't supporting the Element rigs thus far so there aren't any parts there. I don't know of any options beyond the stock parts in the way of axles. Good news is the stock axles seem to be good quality
Old 06-07-2021, 02:57 PM   #6
Right on, thanks.
Incision Universals Pro44 Compatibility - Similar Threads
Incision RC VS4-10 VDI Universals - IN STOCK!! RPP Hobby RPP Hobby 0 09-09-2019 10:04 AM
In Stock - New Incision RC Wraith AR60 VDI Universals! RPP Hobby RPP Hobby 0 01-16-2018 12:58 PM
Vanquish lockers and Incision universals SHOme General Crawlers 8 12-14-2017 05:50 PM
New Incision SCX10 II Universals - In Stock! RPP Hobby RPP Hobby 0 05-09-2017 12:28 PM
