11-14-2013, 09:24 PM | #1 |
Quarry Creeper Join Date: Nov 2013 Location: Pittsburgh
| RC4WD Light Weight Super Bully??
Has anyone drilled or machined the gears on the light weight super bully axles? These are like half the weight of their regular super bully axles, but the gears are solid and they do not offer light weight gears for these axles. Would the gears be strong enough if drilled? |
11-14-2013, 09:47 PM | #2 |
| Re: RC4WD Light Weight Super Bully??
I did some for Stubs and he lost a TON of weight. I think he was a slacker on documenting how much he lost on them but you might bump his thread and ask? Stubs Super Bully!!! |
11-14-2013, 09:57 PM | #3 |
Thanks, he has under the one picture how much he lost.
11-15-2013, 01:20 AM | #4 |
Rock Crawler Join Date: May 2012 Location: Australia
I drilled mine with no issues. I can't tell you what I lost just in gears. I shaved gear cases,drilled gears and went with delrin tubes. Lost approx 150gr per axles. |
11-26-2013, 08:26 PM | #5 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| Re: RC4WD Light Weight Super Bully?? Erik milled mine and did a couple other little tricks. If your doing them yourself I would expect around 0.7-0.9oz per axle in weight loss. I didn't look threw my tread but I'm pretty sure Erik got about 1.5oz out of each set of 4 gears! That's huge 3 whole ounces for the car is a lot of weight and rotating weight on top of that.
RC4WD Light Weight Super Bully?? - Similar Threads | ||||
Drilled Light Weight RC4WD Gears vs. Axial Light weight gears. | OFFROADRCKOREA | Axial XR10 | 1 | 12-12-2012 08:10 PM |
Super Bully Light Weight Comp Axles? | Mikeney | Superclass Crawlers | 14 | 03-20-2010 01:55 AM |
