Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya Bruiser
Thread: Questions???
Old 11-28-2012, 06:14 PM   #1
Default Questions???
I'm on the fence about keeping this truck???Can the front track be made as wide as the rear?Also,can i make the truck flex more(or at all!)?Any help/advice would be great.
CTPATRIOT is offline   Reply With Quote
Old 11-28-2012, 08:29 PM   #2
Default Re: Questions???
I guess you could make some spacers to adjust the track width , as far as flex there are some leaf springs that are made for it that really help , I have seen some on rc4wd and RPP that are plastic and they seem like they would help.
paleblue46 is offline   Reply With Quote
Old 01-12-2013, 11:55 PM   #3
Add weight to the tires, if the spring packs come with the pin holding them together, grind the pin and play with the pack order by removing leafs. By adding a swing shackle to the rear you get additional droop witch equals flex I don't have a bruiser but I do run leaf springs on my rigs so its just trial and error to get them to work good
pook is offline   Reply With Quote
Old 01-13-2013, 05:42 PM   #4
Sinking with the ship
1BadJeepBruiser's Avatar
Chino mod the leaf springs, and throw out all the leaf bushings and replace them with 12 gauge wire insulation.
The front track width can be widened to match the rear by putting a spacer on the front hubs.
Or, if you are looking to convert to 12mm you can buy the axle Cs from me and find someone to machine the rear axle.
-Mike
Questions??? - Similar Threads
tf 2 questions jthellfire911 RC4WD Trail Finder 2 10 02-29-2012 11:14 PM
2 Questions Bestdallasfan6 Newbie General 1 07-08-2008 04:24 PM
A few Questions!! Pyrodon HPI Wheely King 10 05-31-2007 01:32 PM
Questions questions questions quest qowirnl RYY Newbie General 11 10-04-2006 08:18 PM
Questions? krazymtbr General Crawlers 2 01-24-2006 05:06 AM
