04-19-2013, 12:59 PM | #1 |
Rock Crawler Join Date: Jun 2008 Location: trenton
| Full Pull 502 Big Block # 365 fraction engine + 2 bodies 2 themes
well its been awhile . but wait to see what i have instored for this project. i started with a bruiser stock chassis i cant use the center cross member, or the front cross member rc4wd has dual shock mounts for the tf2, but you can also put them on the bruiser chassis. i only had to drill one hole today ive install a 12mm hub convesion kit made by rc4wd part # Z-S0107 this will let me put any style tire and rim on it. but if you deside to keep the stock axles , rc4wd also make a new style rim for the bruiser only Z-W0030 also if you look closely, you ll notice that all the white plastic parts that come with the bruiser kit is black . tamiya makes a complete black set i picked up some rc4wd 90mm shocks (z-d0002) , i beleive the red is discontinued but they do come in silver and black ive installed 2x in each corner also the hub nuts match (Z-S0756) Last edited by SEMIJOE; 04-19-2013 at 01:02 PM. |
04-19-2013, 12:59 PM | #2 |
| Re: Full Pull 502 Big Block # 365 fraction engine +
so these next pictures show a lot to get the 502 in it. i had to take alittle off the front cross member next i had to move the steering bell crank forward. steering works perfect i have red rod tips coming in. this will make it look so much better here's a more of an overview im useing rc4wd steel drive shafts (VVV-S0004, VVV-S0002) i prefitted the 502 and made some adjustments and also made some motor mounts not sure if any body ever saw one of these engine , but there made by rc4wd ( Z-S0059 ) the 540 can motor fits right inside it and has a built in transfer case |
04-19-2013, 01:00 PM | #3 |
next is a radiator, hose, hood scoops and fake electric fans added pull some tires and rims, these are from rc4wd ( Z-T0070, Z-W0135 ) today ive added a couple of framing tube, and a tilt cab. was was ask to show how i did the tilt. the cross member is rectangle. i removed it and replaced with a round one . very simple 1st cab is painted and ready for accessories, also change some of the colors on the engine, i think it looks better now |
04-19-2013, 01:01 PM | #4 |
thank guys! made a weight box added some more detail alittle more on the wiring little more done today front weight box is done rear bumper and lenses came in all red tips came in |
04-19-2013, 01:02 PM | #5 |
ive added the fuel tank time to work on the second body i have for this build im useing a bruiser body added some flares, removed the hood and im adding some different accessories for the 502. she now has twin turbos, add a face plaet to the motor, pullies and a belt. i needed more room. so i have a second radiator i cut in half. not sure on the theme of the truck yet. look for different tires and rims |
04-19-2013, 01:03 PM | #6 |
| Re: Full Pull 502 Big Block # 365 fraction engine + 2 bodies 2 themes
i started on the duallie bed , this side came out really sweet . tomorrow is another day |
04-19-2013, 01:03 PM | #7 |
started on the interior |
04-19-2013, 01:04 PM | #8 |
all done with the red truck |
04-19-2013, 01:04 PM | #9 |
time to switch bodies and theme |
04-19-2013, 01:05 PM | #10 |
cab is painted and pin striped, i received in my new front bumper, need to make mounts for it |
04-19-2013, 01:05 PM | #11 |
i just received in my new engine hoist, what kool about it is that its full functional |
04-19-2013, 01:06 PM | #12 |
| Re: Full Pull 502 Big Block # 365 fraction engine + 2 bodies 2 themes |
04-19-2013, 08:29 PM | #13 |
RCC Addict Join Date: May 2010 Location: Midwest
Killer! |
04-24-2013, 06:37 PM | #14 |
Quarry Creeper Join Date: May 2008 Location: Colorado Springs
Superb work!
04-26-2013, 12:18 PM | #15 |
04-26-2013, 03:17 PM | #16 |
so today i made some phone calls to hooker headers and baer brake systems. hooker headers , hooked me up with a set of zoomies, i beleive i have enough room to fit them baer brake systems , set me up with a set of quad caliber disc brakes. i also beleive i can make these work on this truck. tryin something new. both companies said it will take about a week to get here also ive knowest, im taking on to much paint fumes lol!! |
04-29-2013, 10:40 AM | #17 |
04-30-2013, 02:09 PM | #18 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
Looms sick man. Love the puller. Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 |
05-01-2013, 05:39 AM | #19 |
05-01-2013, 04:02 PM | #20 |
so i received in my baer disc brake kit in from shapeways, really happy with it and the material is awesome for this to work on my r/c truck, i needed to make mounts on the rear axle, havent done the fronts yet , for the bruise rear, it has 2 screws that bolt the rear halves together, which great, so i made the the mounting . next i have to make mounting for the disc caliber. so i went with like a half moon . next mounting the disc itself to the toyota bruiser hub, once i did all this, it all bolted right up. the disc moves freely in the caliber and the rims just misses the caliber so everything went well for the rears |
Full Pull 502 Big Block # 365 fraction engine + 2 bodies 2 themes - Similar Threads | ||||
scale harley frame and engine block im working on | vonclod | Scale Accessories | 4 | 02-18-2011 07:12 PM |
Nitro Engine block repair? | the_ghetto_rig | Non Crawler RC's | 6 | 01-01-2010 08:22 PM |
Big block swap | hitman46mod | HPI Wheely King | 12 | 12-15-2007 06:29 AM |
