03-11-2008, 06:10 AM | #1 |
RCC Addict Join Date: Jan 2008 Location: www.rccrawler.com
| How do I cut the steer stops on the Clod knuckles?
How do I cut the steer stops on the Clod knuckles to improve steering angle ?I couldn't find anything specifically on this ... I would like to know ;What tool to use and hopefully see pictures of how its done? Cheers!
03-11-2008, 06:23 AM | #2 |
Pebble Pounder Join Date: Dec 2007 Location: Montrose
u could use a pair of side cutters to take em off...then use a dremmel or some sandpaper to smooth it out i have not done this yet...but will be in a few hours |
03-11-2008, 06:25 AM | #3 |
03-11-2008, 06:32 AM | #4 |
u dont know what the steering stops are ...but u ask how to cut them? ok... there are little round nubs on the top and bottom of the spindals of the clod axles clip them off and smooth them out |
03-11-2008, 07:54 AM | #5 |
Pebble Pounder Join Date: Dec 2007 Location: Somerset, KY
i didn't completly cut my stops off but i used a rotozip and grooved them to give me more turn
03-11-2008, 11:39 AM | #6 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
You should also cut off the 4 little knubs (steering stops) on each knuckle to increase turning radius. I use a pair of wire cutters or knips, but you can use a dremel tool with a cutoff wheel (use safety glasses) or any other means. How to build a Clodbuster Rock Crawler Its all been asked and explained,so check the sticky's before you get a flamming |
03-11-2008, 04:31 PM | #7 |
Rock Crawler Join Date: Dec 2007 Location: Shreveport, La
why ask? turn the wheels all the way one direction and hold it up to your face to see just what is holding them back from turning farther! Then Cut, Grind, Sand, File, hammer, torch, however you want |
03-11-2008, 05:51 PM | #8 |
03-11-2008, 05:59 PM | #9 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
03-11-2008, 06:01 PM | #10 |
Thanks for the help! |
03-11-2008, 06:09 PM | #11 | |
