04-20-2008, 10:09 PM | #21 |
Pebble Pounder Join Date: Apr 2008 Location: springfield
ok, you guys are talking me into keeping the clod....if i buy the pimp cane, what else exactly would i need? I have speed control that will handle about any brushed motor combo, and the radio. I know i would need a better servo. so help me out in getting the list together. could i run my stock clod tires just to get started???
04-21-2008, 02:54 PM | #22 |
Newbie Join Date: Apr 2008 Location: Middle
The great thing about the Pimp Cane is you really don't need much--no shocks or links. It sounds like you just need batteries and motors right now.
04-23-2008, 01:17 AM | #23 |
so if i get the pimp cane i need nothing else except 2 motors, and i can use my current servo setup that is attached to the axles? also do i have to make or buy some sort of body mounts?
04-23-2008, 05:11 PM | #24 |
Yes you will need two body mounts. The chassis won't interfere with most servo locations, but something like an ESP mount won't work because it will be in the way and the pittman/servo saver hole is used to attach the chassis to the axles.
04-26-2008, 11:08 AM | #25 |
well a guy at work says he is buying my clodbuster. so i will just wait and see if he actually brings in the money. If he does not get it i am going to buy the pimp cane and see what i can do with it. If he does buy it,,,,then some money to get another crawler of some kind. probably the ax10 at this point. Thanks for all of th help you guys are great! |
