| | #1 |
| Pebble Pounder Join Date: Sep 2004 Location: Brooklyn, NY
| I just finished building my crawler. I took it out side on to the street and drove it around. This is my first crawler so I think I did something wrong. I think its the shock angle. I think that it might be too steap. her is a link to a drawing I did. the black lines are the links, the red lines are the shocks: http://putfile.com/pic.php?pic=5/12217383938.jpg&s=x402 The problem Im having is firstb of all when I turn and drive the truck 3-wheels. no matter how fast I go. also when I turn then return to going straight, the whole chassis is tilted to the direction the truck was turned to. The only way to get the chassis back to being straight is to turn the other way and drive. I know that this is wrong. So is it because of my shocks being too steap? (The shocks might be even steaper than in the pictures) |
| Sponsored Links | |
| | #2 |
| I wanna be Dave Join Date: Mar 2006 Location: One Legend.
| You didn't say, but i assume you have a shafty... Probably a TLT from your drawing. Do a search on "Torque Twist" to learn about fixes ranging from stronger springs, link locations, shock position, etc. Hope that helps! |
| | #3 |
| oh sorry. Its actually a CLOD. The chassis is a cutom one. It doesnt look exactly like that but its close enough. |
| | #4 |
| Then scratch everything I said above! |
| | #5 |
| Yeah if I had a crawler with drive shafts I know it could have problems like a 1:1 truck. Problems like torque twist. but its not a drive shaft truck so...... Was I correct about the shocks being too steep? |
| | #6 |
| <------- Not a Clod guy. Can't be of any help to you. |
| | #7 |
| Pebble Pounder Join Date: Oct 2004 Location: Murphysboro
| sounds like your shock/spring combo is too soft. jim |
| | #8 | |
| | #9 |
| I wanna be Dave Join Date: May 2005 Location: Anchorage, Alaska
| I can't see the picture (blocked at my work |
| | #10 |
| Rock Stacker Join Date: Dec 2005 Location: Coos Bay
| I have a clod with a Gecko2 chassis, and had the same problem. I had the shocks almost vertical, and it did the same thing. I laid them down and it almost went away. They were like this ( | | ), and then I put them like this ( / \ ), and it made it a lot better. |
| | #11 |
| Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
| Stand up your shocks more. This will increase firmness but decrease travel. |
| | #12 | |
Also If I make them verticle, I decrease travel- well I run savege shocks and they have quite a bit... so what should I do then? | |
| | #13 |
| Pebble Pounder Join Date: Mar 2006 Location: hillsboro
| I just went through the same thing with my modified clodzilla chassis. I reccomend mounting the lower shock mounts closer to the chassis pivot point and the upper shock mount further upward. You still want a little angle , like about 70 degrees. Mounting the top further up provides more uptravel or the use of longer shocks. Mounting the lower closer to the pivot point allows more down travel. Do this and play with spring tension and lower shock mounts to adjust the angle accordingly. |
| | #14 |
| Newbie Join Date: Nov 2005 Location: Westland
| Driver, Have you checked your 4 links to make sure they're all the same length? I've also found that those shocks sometimes they bind up when they're laid down like that because it puts pressure where the shock shaft goes in the housing, sort of like trying to break a toothpick in half....The other thing is you might need a stabilizer bar, hope this helps some...J.J. |
| | #15 |
| Quarry Creeper Join Date: Jun 2005 Location: NOrthern Cali
| for savage shocks,since they are longer,they would need to be mounted more vertically.Your right,the shock angled like that is most likely to be the main cause of your problem.Try fabbing up some shock mounts that would extend out.Also,try some stiffer spring/shock oil combo.Does it lean toward one side or multiple sides? |
| | #16 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| do you have stuff mounted on the chassis? It sounds like you have weight up top above the roll center, causing the chassis to flop back and forth. We need a pic of the real thing. |
| | #17 | |
Ill try to get a pic of even a video asap. What I dont understand are these trucks: http://www.rccrawler.com/forum/tamiya-tlt-crawlers/6756-tlt-crawler-picture-archive-print.html the shocks are mounted just as steep as mine or even steeper and they work... so whts the deal? | |
| | #18 |
| TEAM MODERATOR ![]() Join Date: Jul 2004 Location: Chit Chat
| Could be spring rate. |
| | #19 |
| Well I know that the Maxx shocks a alittle stiffer than the savage shocks. but at the same time I did add like an inch and a half of spacers to the savage shock and I still had the same result. Yesterday I relocated the front upper shock mount so that its more verticle. I left the rear alone since its going to be quite some work to malke them verticle. Anyway, withe the front shocks almost verticle, the truck still did the same thing. |
| | #20 | |
| Thread Tools | |
| Display Modes | |
