06-27-2006, 09:55 PM | #21 | |
Rock Crawler Join Date: Feb 2004 Location: Michigan
thanks | |
06-27-2006, 09:57 PM | #22 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
have smaller tube on both sides of the center tube, stick some thick wire through and they'll act as guides. see i have the knowledge but i lack the resources. Last edited by clod booster; 06-27-2006 at 10:10 PM. |
06-27-2006, 10:09 PM | #23 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
Pretty cool, nice setup you've got there.
06-27-2006, 10:19 PM | #24 |
The way you have your idea Clod Booster, it seems to me the middle part would be a very weak link. Two guide rods wont take much of a fall without bending compared to the drawer slider rcracer is using. Maybe three triangulated guide rods would work better, and it would clean up the design a bit. Your rig is very similiar to Ace's old build, but you built it as a stick design. Very cool and probably all kinds of fun to play with! |
06-27-2006, 10:20 PM | #25 |
well i would try to make sur i have a strong enough matterial.
06-27-2006, 10:23 PM | #26 | |
thanks | |
06-27-2006, 10:29 PM | #27 |
the thing is i dont have any crawlers but the one that is being built right now, i just have this sort of infinite knowledge on rcs but i lack the resources to build all my designed trucks. i designed almost tis whole system within five minutes sitting at my computer.
06-27-2006, 10:39 PM | #28 | |
Sounds like you need a job to get some money (aka resources). Then you can put your "infinite knowledge" to work! | |
06-28-2006, 03:17 AM | #29 | |
Quarry Creeper Join Date: Jan 2006 Location: Henderson
06-28-2006, 06:20 AM | #30 |
Just brilliant , very ingenious, i was thinking i bought a 4 ch acoms fm radio, ch 3 has 100%-0-100% movement, ch 4 has 4 100% adjustable positions, that way you can have 4 different wb , what do you think |
06-28-2006, 06:30 AM | #31 | |
until I can afford a 4 channel I will have to make due with the 3 channel. I ultimatly would love a 4 channel, would give me rear steering and variable on the wb. I was thinking about ditching the front chain drive for a ez-start from say a traxxas motor. I'm wishing now that I didn't give that stuff away, goes to show you never know what you have til it's gone. I have to get some parts together to sell so I can fund a 4channel. Worse case I could sell off my Blizzard. LOL | |
06-28-2006, 07:05 AM | #32 |
i bought an acoms technisport 40 mhz fm, it came with 3 servos included |
06-28-2006, 07:18 AM | #33 | |
06-28-2006, 07:18 AM | #34 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
06-28-2006, 07:37 AM | #35 | |
What I don't see is what gearbox he used and did he use an additional esc or just the reciever? thanks Last edited by rcracer; 06-28-2006 at 07:45 AM. | |
06-28-2006, 07:44 AM | #36 |
From the looks of the 2 videos on page 3. It appears to have a seperate tranny and motor on the frame rails. I'm not sure how he ended up hooking everything together.
06-28-2006, 07:57 AM | #37 |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Pretty ingenious......nice work. Bet you could do some crazy antics with the wheelbase changing if your mind and hands are fast enough :-) Jay |
06-28-2006, 12:41 PM | #38 |
i swear you guys never ses to amaze me, enginuity is crazy around here, first the cable steer, now this!
06-28-2006, 01:43 PM | #39 |
Rock Crawler Join Date: Sep 2004 Location: a place of settlement, activity, or residence.
Very cool rig. At the MWRCA comp there were a couple of obstacles that an adjustable wheelbase would have made quick work of. Might be worth trying myself if I build another comp crawler.
06-28-2006, 02:31 PM | #40 |
I wish we had comps in michigan, once it's done I might have to venture out to other states to see how it really does against quality rigs in rougher terrain than I have.
