09-23-2006, 06:22 PM | #1 |
Quarry Creeper Join Date: Aug 2006 Location: olympia
| Built my first Clod Axles
I got the fronts done and used all ball bearings, and the TTR CVD. What else can I do to beef these up? I am trying to decide if the rear should be the TTR straight axle or the CVD. Do most people run a rear steering? Does anyone sell a 1/4 scale steering mount? I am also trying to decide if I want to use there diff assembly. I guess the jist of the ball diff is that if one side starts to slip, it will transfer power to the other side instead of unloading? The most awesone rock rings: http://www.rccrawler.com/forum/showthread.php?t=41846 Thanks, Tim www.DrasticSports.com |
09-23-2006, 06:27 PM | #2 |
contact syco133 for 1/4 scale mounts, you can beef up the xle ends with CPE parts: http://www.crawfordperformanceengine...59057914.27416 |
09-23-2006, 07:15 PM | #3 | |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Get it done, come to the mwrca comp on the 6th | |
09-23-2006, 08:35 PM | #4 | |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
for instructions on do it yourself. Or Check the www.thecrawlerstore.com for a cool locker to replace the diff. | |
09-23-2006, 09:01 PM | #5 | |
| Trac Gear
Couldn't I get the aluminum track gear from rc4wd for just $5 more? Quote:
09-23-2006, 09:03 PM | #6 |
Yep. You can.
09-23-2006, 09:21 PM | #7 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
it'll add weight and you wont have to worry about stripping out the hex.
