10-21-2006, 01:21 PM | #1 |
Newbie Join Date: Oct 2006 Location: Essex
| diff locking, help
k, i need to lock my diffs. i dont know what method i should use. i would use epoxy, but dont want to mess up. how are you supposed to glue it perfectly without putting the gearbox back together? or do you epoxy it then put it together and let it dry? i was doin some research and i found a really clever way to lock txt diffs, but i dont think it works with clod diffs. it involves moving one of the three middle gears directly inbetween the other two. heelp
10-21-2006, 01:34 PM | #2 |
i used hot glue before but i know do this: http://www.rccrawler.com/forum/showthread.php?t=46932 |
10-21-2006, 03:22 PM | #3 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
For a limited time, that price linked above will include shipping to the UK!
10-21-2006, 03:33 PM | #4 |
yea, thats a sweet kit for sure, but i dont have much of a budget left...at all. any tips on something cheaper (gluing, etc.)?
10-21-2006, 03:38 PM | #5 |
Rock Crawler Join Date: Jan 2005 Location: Bethlehem, GA
JB weld is your friend. I used JB welded mine once and never looked back.
10-21-2006, 09:25 PM | #6 |
Newbie Join Date: Aug 2006 Location: Spokane
| what happen to the sticky on how to lock clod diff Whatever works to stop the 3 little gears from turning. |
10-22-2006, 04:33 PM | #7 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
jb weld all the way..
10-24-2006, 10:54 AM | #8 |
Rock Stacker Join Date: Sep 2004 Location: Spanaway,WA
I put screws through the main diff gear to mesh with the teeth of the side gears then filled the diff with hotglue.
10-24-2006, 04:51 PM | #9 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
I would not use jb weld, I did this and it broke very quikly, jb weld is not for plastic. Use a high temp hotglue gun. I have never had one fail with hotglue.
10-27-2006, 08:29 PM | #10 |
i ended up using hot glue and it hasnt failed me yet. i used about one whole stick of glue in each diff, so i couldnt imagine it coming apart.
10-28-2006, 02:55 AM | #11 |
Rock Stacker Join Date: Sep 2006 Location: Port Angeles
I used epoxy on the gear-to-gear contact areas, then after it dried i filled it with hot glue. It seems to be working pretty well, havent had any problems with it yet!
