12-18-2006, 09:36 AM | #21 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
Lookin good. You might want to consider a 2/3A or 4/5A knuckle pack on the front. It will be a big difference in top weight. If you can set the truck on it's side and it not tip over, then you're golden. I try to keep all the weight below the top of the tires and it works great.
12-18-2006, 04:05 PM | #22 |
Rock Stacker Join Date: Nov 2006 Location: knoxville
Thanks, I am planning on the under knuckle batteries as soon as my RC4WD aluminum knuckles & aluminum axle housing come in. Balance is surprisingly good now.
12-19-2006, 07:52 AM | #23 |
Heres a couple pix of the new knuckle packs I make. They barely fit, but they're much better than the huge SC's that I had mounted on the links. The aluminum knuckles look way harder to make packs for though. You will pry have to use a 2/3 A cell like the Elite1500 or IB1400. |
12-19-2006, 07:19 PM | #24 |
I ordered a set of Thorn wheels. These used with the RC4WD aluminum knucles and aluminum axle tubes should have plenty of room for knuckle packs. I'll keep y'all posted.
