12-31-2006, 05:46 AM | #1 |
Quarry Creeper Join Date: Dec 2005 Location: United Kingdom
| Removing deans connectors on Pimpcane.
I have a 17" Pimpcane. It has on the knuckle battery packs. The batteries then connect to the esc which is located at the front of the truck on top of the pimp cane chassis. The problem I had was that every time I undid the deans connectors I caught the body posts and was was forever loosening them. I was also concerned about any wires becoming loose due to any heavy- handed disconnecting of the connector. I have extended the wires on the esc and these now run to the rear of the truck. I also extended the wires on the battery pack to the rear of the truck which is where they now connect using the deans connector. I also cut down a plastic 100mm x 8mm wall plug to around 25mm long. The wall plug is the type that is found on a hammer fix type fixing. This is fastend to the c channel at the rear of the truck by using araldite rapid. The wires that I extended now loop around this wall plug and that stops the wires moving forward during use. The cables are then tied to the chassis using velcro straps. Now when I change batteries I just undo the velcro, lift the cables well above the truck and I am now able to easily undo the deans connectors without causing any damage or any undue pulling on wires. I am not sure what others do, but this appears to be working for me. I now just have to tidy the wires and install heatshrink on the connections. |
12-31-2006, 08:33 AM | #2 |
Quarry Creeper Join Date: Aug 2004 Location: North Las Vegas
This is one reason I run the power pole connectors. They aren't as hard to pull apart and that would get rid of your hard jerking to get them apart and save the shell in the long run. Any pics?
12-31-2006, 08:58 AM | #3 |
I will post some pictures as soon as I have finished. I have not heard of the power pole connectors before.
12-31-2006, 09:50 AM | #4 |
Never had an issue my Deans?
12-31-2006, 10:04 AM | #5 |
Hello Dezfan. All my deans are really hard to undo. They are so difficult I have to grip one set with a pair of grips as with my hands I cannot pull them apart. I bought the deans as a set of 6 pairs. I have not used deans connectors before. I presumed that they would all be this difficult to undo |
12-31-2006, 10:18 AM | #6 |
Here is a picture of the power poles. Ask your lhs about getting them if you want to try them out. |
12-31-2006, 11:46 AM | #7 |
Quarry Creeper Join Date: Feb 2006 Location: Surrey B.C Canada
I've used them in the past 2 They should help you out |
12-31-2006, 10:45 PM | #8 | |
12-31-2006, 10:51 PM | #9 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
He is hitting the plastic or is pushing down on the wire while soldering and its making the metal pins moving a little, hard to get out. I did that my first pair of deans! I bet thats your problem!
01-01-2007, 02:09 AM | #10 |
Hello Clodcrawling. Thanks for the advice. I will double check the soldering today. Dezfan. They are original Deans and are not copies. I bought the truck of Syco. The Deans connectors that he installed are also very tight. I think he had the same problem as me, as the body posts where loose when I got the truck. |
01-01-2007, 03:09 AM | #11 |
I'd swap over to the power poles. Dean's aren't the best, direct soldering is. Deans, Sermos and Corally's are all very very good and with almost zero power lost. Almost as good as direct solder but who wants to keep their soldering iron hot and in their back pocket when out in the bush?
01-01-2007, 03:46 AM | #12 |
Thanks for the info Minijosh. I have just tried a search and have only found one place in the UK that the search finds. The powerpoles are 2.50 a pair. However on ebay I can get the cheaper fron the USA. What rated amperage are you using on the connectors. In response to the earlier comment regarding catching the connectors whilst soldering. have just looked at the connectors. They appear to be how they where fabricated. All the pins are horizontal and tight down against the edges in the plastic connector. The edges of the connectors are not damaged by the soldering iron. They are just so damn tight to undo. |
01-01-2007, 09:44 AM | #13 |
Dang I don't remember which one. Just look up the rcboyz on ebay and buy that amperage. I'm not saying buy from them but those are the right size. Tower Hobbies also carries them. Call your LHS and see what they got. Sometimes I can't wait so I buy locally but if I can wait, I'm using my military address to get expensive stuff into the UK. No import tax.
01-01-2007, 10:04 AM | #14 | |
Dean's ARE the best. | |
01-01-2007, 10:19 AM | #15 | |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
How can adding any connection in line of you wiring be more efficient than not having that connection? | |
01-01-2007, 10:34 AM | #16 |
Hard to beleive huh.....
01-01-2007, 10:55 AM | #17 | |
• Deans Ultra plug: 0.0009 ohm • PowerPole: 0.001 ohm • AstroFlight: 0.0011 ohm | |
01-01-2007, 11:27 AM | #18 |
I wanna be Dave Join Date: Nov 2005 Location: Here
I was a Dean's believer until I tried the Power Poles. They are so easy to install. You can either crimp them, yes no soldering, or what I do...I place the clip in a vise facing up. Insert the wire in the clip and allow solder to pour in the clip. Let it cool and then push the clip in the holder. So easy...Plus you can customize the layout of them so that you don't accidently plug a the wrong things together. Check them out http://www.andersonpower.com/product...onnectors.html I bought 25 pair for $15 on ebay... |
01-01-2007, 11:16 PM | #19 |
Newbie Join Date: Nov 2006 Location: Franklin
yeah but if you crimp the power poles like somepeople dop and they get frayed then it increases your motor heat and and that good stuff
01-01-2007, 11:42 PM | #20 |
Pebble Pounder Join Date: Dec 2006 Location: nampa
i had those power poles on a few of my trucks and i hate them!! the contacts in them get loose and pull away from the other contact the wrong bump and it would lose power and i just about went crazy and ive had the same prob as you with deans and it was probly that you held the sodering iron on the deans to long and moved the contact or sodered the to ends and pluged them in while they were still a little to hot
