01-05-2007, 11:36 AM | #1 |
Pebble Pounder Join Date: Jan 2007 Location: So.Cal
| uhmmm help on gearing on clod
Well can someone tell me which gears will fit my clod buster? .. As a newbie and looking for help, I bought what shoker told me and they don't fit ! Thank you shoker |
01-05-2007, 11:44 AM | #2 |
RCC Addict Join Date: Sep 2005 Location: ...Here & There
You need a 32pitch pinion to match the gears in the case. The lower the # of teeth, the more torque you'll have. 9tooth and larger will fit w/o motor mounts but 8tooth & below will NEED them. You can get motor mounts for your C L O D from several Vendors on the board. You could also try using a higher turn motor to get away w/ less pinion... ie; 65turn or 75t lathes w/ 9 or 10 tooth pinions, should be close to a 55t w/ 8 tooth pinions. I hope this helps ya. Good luck! Last edited by raytard; 01-05-2007 at 11:48 AM. |
01-05-2007, 05:14 PM | #3 |
Did you read the stickies? How to build a Clodbuster Rock Crawler Clod FAQ and Directory Both of them list places to get adjustable motor mounts. http://www.rccrawler.com/forum/showthread.php?t=47958 http://www.thecrawlerstore.com/geartrain.html http://www.crawfordperformanceengine...T4&log_pid=yes It is possible to run a 10 tooth without any mods. You just remove the brass sleeves from the motor mount screws and that gives you enough slop to get the gear mesh right. Another option is to dremel a slot out of the lower hole (or just enlarge it a bit) to allow you to adjust the motor. Adjustable mounts are the best way to go though. |
01-05-2007, 11:22 PM | #4 |
Great info thank you !! This week i will start building my chassis i hope by the nextweekend will be ready to roll |
01-06-2007, 11:55 AM | #5 |
Quarry Creeper Join Date: Feb 2006 Location: Surrey B.C Canada
Thats why this site rocks A guy asks a question and everyone steers him in the right derection Good luck on your build bud |
