Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: What ESC for Dual Motors
Old 03-01-2007, 01:06 PM   #1
Default What ESC for Dual Motors
Hello,
I did a search for dual motor esc and clod esc and did not come up with much.
I am trying to find a relatively cheap ESC to use on a Clod crawler. 55t motors. Is the Traxxas the only way to go ? Or would it be better to run 2 ESCs ? If so how would I set up 2 of them ?
Thanks
wnacrsh is offline   Reply With Quote
Old 03-01-2007, 01:07 PM   #2
Are you running four wheel steering or just the front?
Old 03-01-2007, 02:00 PM   #3
for two 55t motors you need an esc that can handle a 27.5 turn motor, so most esc's will work.
the next issue is the bec power, which is why run2jeepn is asking about servos...
rcktpwrd is offline   Reply With Quote
Old 03-01-2007, 03:41 PM   #4
Yes,
It is 4 wheel Steer.
Old 03-01-2007, 04:14 PM   #5
i have a novak super duty xr that i had bought for my clodbuster figuring that i would be turning it into a crawler pretty quickly the speed control can handle unlimited turns , a crazy amount of cells and puts out 3 amps bec but it definately wasnt cheap 138.00 from tower
mch441 is offline   Reply With Quote
Old 03-02-2007, 01:25 PM   #6
i was thinking about going with either the new novak super duty or save a few bucks and a tekin 2.
what do you all think?
does anyone use the tekin 2 with 2 motors and f+r steer?
i got 55t motors, and 2 jr z650m servos
intheworks is offline   Reply With Quote
Old 01-17-2013, 11:09 AM   #7
Default Re: What ESC for Dual Motors
i called novak a tech told me the super duty xr is for 1/10 scale. i have g made 1:8 stealth the super duty xr wad getting hot .after 10 min. and shutting down after it cooled it was fine again. [2 7cell batterys ] the tech said to try the goat 3s.but i would need 2 of them and a y harness to connect if u dont have enough chanells . he also said goat 3s was 1;10 scale and would not be sure i may need something heavier yet .im lookin for help also .i have 2 motors 55 turn brush and steering ft n rear. 1 more thing he said volts r ur friend and keep the esc cooler he recommended 2, 3 cell lipo and make sure motors r 12 volt [ mine r ] hope this helps i need esc also i did not buy yet not sure im looking 4 something heavier if i can talk to the right person
secsm is offline   Reply With Quote
Old 01-18-2013, 03:21 AM   #8
i have the holmes hobbies esc using 55 turn motors and dual steering and it really works great. it was just over 100 shipped and its water proof. it can also handle up to 6s lipos.
spdyracer is offline   Reply With Quote
Old 01-31-2013, 03:01 PM   #9
I also have a clod and am in need of a new esc. Mine is not a crawler but has a racing chassis and will be used as a basher. would the holmes hobbies esc still be good for this also? I am assuming the esc your refering to is the torquemaster BR-XL?
'65belair is offline   Reply With Quote
Old 02-06-2013, 09:43 PM   #10
im running 2 traxxas xl5 esc in mine. partially because i already had them, but they are also fairly inexpensive to replace them (they were the cheapest brushed esc at the lhs)
Sent from my iPod touch using Tapatalk
c0bra is offline   Reply With Quote
HTML code is Off
