04-03-2007, 12:05 AM | #1 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
| BTA steering kits?
Ok, I have a set of TTR's CVD's and wanting to do BTA steering but want to be able to get full steering where the knuckle arm is close to touching the ball part on the axle tube. Anybody runnin a setup to give them this much turning? Post up pics of your setup too please.
04-03-2007, 09:54 AM | #2 |
I have mine about that close. But to given tighter turning you have to make your own bottom link. You can see I still have more room to go, but the TTR's link hits the housing. The housing is really thin there. So grinding that is out of the question. |
04-04-2007, 12:14 AM | #3 |
That looks prety cool, with that kind of steering front and rear on a super I bet it would turn on a dime. I'm suprised havn't had more replys on here. Last edited by LIKES2CRAWL; 04-04-2007 at 12:17 AM. |
04-04-2007, 11:34 AM | #4 |
Newbie Join Date: Oct 2006 Location: Point Pleasant
OMG ... that gearbox is really chewed up BTW ... the Etzler Super Steering System turns tighter the TTR (plus the steering link is made from titanium ... less likely to break and it's easily to service than the TTR system ) |
04-04-2007, 12:07 PM | #5 |
| Never heard of it, and if it's so much better why havn't I seen others running it? How about some pics or a link on where to find this Etzler System.
04-05-2007, 01:13 PM | #6 |
Well the only info found was it's made by John Etzler and his website has nothing on it and has been outdated since early '06. Thanks Spence for the help searching.
04-06-2007, 11:59 AM | #7 | |
Where to buy and pics of this 'super' linkage would be good. The TTR cf bta linkage pictured above breaks too easily if you have a bad tumble and as was mentioned it hits the housing before the knuckles and cvds run out of steering. I made one for a freind out of aluminum angle and it worked really well...have to see if I can find a pic later. | |
04-06-2007, 12:03 PM | #8 |
So I'm trying to figgure out some better steering solutions and everybody else must be happy with there crappy steering, cause nobody is responding to what they have done to improve there steering. Let's see what you have done to improve your steering!
04-06-2007, 12:05 PM | #9 | |
04-06-2007, 02:49 PM | #10 |
RCC Addict Join Date: Dec 2005 Location: Beaver Falls
When i look at that bta steering link, it curves toward the axle when it comes off the knuckle. Couldn't we just make a link similar to the one you can buy but have it come straight across and then out to clear the diff? I think that'll give you about 1/8 or 1/4" more space and it won't hit the axle. I dunno..just throwing ideas out there.
04-07-2007, 11:50 AM | #11 | |
View of bottom side of draglink: and top side view of draglink: Installed: Last edited by Natedog; 04-07-2007 at 02:46 PM. | |
04-07-2007, 06:35 PM | #12 |
Newbie Join Date: Sep 2006 Location: richmond
does the bta really work better then regular
04-07-2007, 06:40 PM | #13 |
You don't catch you steering links on things like when it is in front of your truck.
04-07-2007, 06:48 PM | #14 |
RCC Addict Join Date: Feb 2005 Location: Guam
i've got to get me a bta setup |
04-07-2007, 07:56 PM | #15 |
Make your own...it's pretty easy just takes time.
04-08-2007, 02:27 AM | #16 | |
04-09-2007, 01:15 AM | #17 |
Ok, well I have some pics of a setup that is done by Rogue670 and it looks to be prety good. I'm gonna run it on one of my clods and see how it dose. Last edited by LIKES2CRAWL; 04-09-2007 at 02:03 AM. |
04-09-2007, 02:59 PM | #18 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
the only problem i saw was the servo turns over center the way it is now and the way the servo mounts you can't use a longer servo arm
04-10-2007, 12:05 AM | #19 |
04-10-2007, 01:49 PM | #20 | |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Jay | |
