07-08-2007, 02:20 PM | #21 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
Crawled it with batts on the front axle for the first time today, and the difference was amazing, it just climbed straight up anything I pointed it at. Batteries on the knuckles is definately a good change. Then I broke a shock mount, snapped a servo horn, and crushed a power lead. Time for something of a rebuild before the UK Nationals! |
09-03-2007, 03:18 AM | #22 | |
So, the rebuild before the Nationals never happened. Maybe I'd have got 1st if I'd done it sooner, but never mind. Remember the old list?: Quote:
Problem now is, when the servos get in a bind, they just flex the axle casing, C's, and knuckles... ...and I want more torque from the motors. Last edited by 4link4eva; 09-04-2007 at 05:57 AM. | |
09-03-2007, 06:53 AM | #23 |
Pebble Pounder Join Date: Dec 2005 Location: Parts Unknown (Eastern Sho, Maryland)
I'm going to try and tie the servo mount into the axle tube or case with a third "leg" I've seen it here and the Crawler Store has one but it's out of stock. My servo's just crank the axle stays up and down.
09-04-2007, 05:59 AM | #24 |
The rear suspension has been heavily modded. I think this setup will be much more stable, and stronger, too. Anyway, here are a few pics, even if they're a bit poor: This is the new amount of flex with the new setup, and it's much more gradual, and not as sloppy. It's not been finished up yet, but this is pretty much all the welding done. Might add some bracing yet though. |
09-04-2007, 06:02 AM | #25 | |
Try mounting the servo flat against the side of the axle casing, using as many mounting points as you can. | |
10-06-2007, 09:40 PM | #26 |
I joined the Band! Join Date: Aug 2007 Location: mission b.c canada
| clod tuber
nice rig lots of articulation maybe to much , but very nice
10-12-2007, 02:07 AM | #27 |
RCC Addict Join Date: Jun 2004 Location: ORegon
| theoretically i believe bends in the links won't have any affect on the geometry. the geometry of a link is a straight line from center of ball to center of ball. just think about it a bit. it makes sense.
10-13-2007, 06:11 AM | #28 |
| Yep, the geometry is not affected at all. Think about it, even if you have a spiral link, it's still only a measurement from point A to point B, and if those measurements are equal then all is well. |
11-04-2007, 10:18 AM | #29 |
Well, recently coursework has been eating all my free time, but today I couldn't have looked a Word Document in the eye. Out to the garage I went. I got around to starting on something I've been meaning to do for a while, making some rigid side panels that would slide over the rocks rather than be punctured by them. Here's what I came up with: |
11-05-2007, 04:14 AM | #30 |
Newbie Join Date: Sep 2007 Location: New Zealand
wow, really nice build! Love the tuber. If you'd be interested in either selling that one or making a replica for me, hit me with a pm |
11-05-2007, 02:10 PM | #31 |
RCC Addict Join Date: May 2006 Location: Aroostook county
wow great looking crawler, mate..and as I was telling you on MSN it is amazing how far you've come..I mean look @ the start of the thread |
11-05-2007, 02:18 PM | #32 |
Same tubes still... ...just refined. I've learned a helluva lot over the past few months. Cheers Ant. |
07-09-2008, 02:47 PM | #33 |
Wow, old thread. It's that time of year again, UK nats on Sunday. Here's what i've got now Made some big, strong and long rear links, from 12mm Delrin rod. Also bought a pair of Castle SideWinders, a pair of Castle BEC's, and some 3S LiPos (2 x 1500mah 25C and 1 x 2200mah 25C). I've 'tested' this in the garden as it is now, and the power from the LiPos is unreal. Need more weight on the front end, methinks. Would recommend the SideWinder to anyone, great peice of kit, as are the BECs, and JRH (www.holmeshobbies.com) is a great seller. |
08-06-2008, 03:32 PM | #34 |
Newbie Join Date: Jun 2008 Location: Sweden
Nice tuber and a clever way too put the battery |
