06-07-2007, 09:50 PM | #21 |
06-07-2007, 09:50 PM | #22 | |
Rock Crawler Join Date: Jul 2006 Location: Olympia
06-07-2007, 09:51 PM | #23 |
06-07-2007, 09:53 PM | #24 |
06-07-2007, 09:58 PM | #25 |
| I'll go along even though were hijacking..... = rolleye's=whatever! Every little thing helps in a build...otherwise why would people run knucklepacks, mount there servo's as low as possible, etc. etc.. Your probably a great driver, but not the best. So again every little thing helps or you would be competing in a stock clod. |
06-08-2007, 06:36 AM | #26 | |
http://www.rccrawler.com/forum/showp...5&postcount=32 | |
06-08-2007, 07:47 AM | #27 | |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
I haven't modded my gearcases because they may not be the cases I actually use. Heck, I'm even going to change the kingpin screws to button heads. | |
06-08-2007, 07:51 AM | #28 |
06-08-2007, 09:34 AM | #29 | |
On the JP website it looks like the knuckles inset rather than having an area to just ride on the bearing. | |
06-08-2007, 09:38 AM | #30 |
I'm lost...which bearings on the knuckle are you referring to? Kingpin or wheel axle? Either way, there are no spacers. I took about 1mm off each kingpin boss on the Jp knuckles. After that I used the RC4WD kingpin screw and bearing...done deal. I also used both Jp bearings for wheel axle in the knuckle, omitted the outer bearing in the axle tube, and just used the inner bearing in the axle tube. |
06-08-2007, 11:38 PM | #31 | |
Sorry, thought this would be a simple Q&A. The Derlin spacers that come with rc4wd knuckles keep you from pinching the bearing, i was just wondering if these had it built in. It would be nice if they did. | |
06-09-2007, 06:57 AM | #32 |
These knuckles aren't designed to be used with these axles. If you trim the knuckles properly you don't need spacers and you won't pinch the bearing. |
06-17-2007, 05:01 AM | #33 |
I couldn't help notice you have Alumn Hex's on those CVD's. Are those still left over from the older sets or the New ones that His coming out with? |
06-17-2007, 09:54 PM | #34 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Left overs he was talking about that earlier in the thread. I have to say very nice rebuild so far, I to am in the rebuild process. I just dumped another $400 into my super to get it ready for nationals. Hate showing up with a new fresh truck that I haven't run a season with, but I need the hardware. |
06-20-2007, 09:43 PM | #35 | |
06-20-2007, 09:49 PM | #36 |
I retract my statment....... |
