06-07-2007, 07:20 PM | #1 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
| Rebuilding the Stick
Tore apart my stick to scrounge up parts for another rig, time to get the stick back in action. Parts: TCS Stick (Black backbone) TTR/MIP CVDs RC4WD delrin gears RC4WD axle tubes JP knuckles Mamba Max ESCs E-Flite Power 10 outrunners DX6 Airtronics 94359s TTR BTA kit The servos and servo mounts will likely change, as will a few other things. |
06-07-2007, 07:31 PM | #2 |
I like the way you used JP's knuckles with the bearings on the RC4WD knuckles, smooth steering! I tried using just the aluminum tubes but the plastic centers tore out after a little while.
06-07-2007, 07:41 PM | #3 |
Now those are axles are PIMP! |
06-07-2007, 07:44 PM | #4 |
I can't wait till mine go pimp!
06-07-2007, 08:11 PM | #5 | |
Yup, yup. Just need to be sure to carry spare bearings for the kingpin to comps incase they fail. It is! I like that upper link mount. | |
06-07-2007, 08:15 PM | #6 |
06-07-2007, 08:18 PM | #7 |
RCC Addict Join Date: Mar 2007 Location: des moines
looks good.how do you like those motor Im looking for some new motors for my hustler
06-07-2007, 08:30 PM | #8 |
Motors are nuts. I've stripped counter gears by driving full throttle then letting off...too much rotational mass combined with 100% drag brake. Could get away with 100% Drag on the OG Revolvers...not with these. Last edited by JasonInAugusta; 06-07-2007 at 08:32 PM. |
06-07-2007, 08:40 PM | #9 |
cool thanks,what size output do they have.also if you dont mind say what tooth pinions are you useing
06-07-2007, 08:44 PM | #10 |
5mm I turned the output shaft down in the lathe so I could run standard pinions. What tooth? Not sure. |
06-07-2007, 08:48 PM | #11 |
aw I wish i had a lathe it hard to find someone to turn down the motor shafts
06-07-2007, 08:54 PM | #12 |
I couldn't actually turn them down in the lathe, just chucked the shafts into the lathe. The steel is so hard (basically a drill blank) that I couldn't machine it. The trick was to use sandpaper on a file and a ton of patience to turn it down. Then I had to do the 2nd one. |
06-07-2007, 08:56 PM | #13 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
Sweet Jason....where did you get those Metal cvd wheel nuts???? I hate the stock plastic ones!!
06-07-2007, 09:02 PM | #14 |
The first batch of TTR CVDs had the aluminum hex adapters. Depending on the wheels/adapters I'm using at the time, I use the O-ring or a 10-32 set screw to hold the drive pin in place. |
06-07-2007, 09:04 PM | #15 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Dang Jason, those axles are almost as good as mine........minus all the aluminum and cvd's and such |
06-07-2007, 09:04 PM | #16 |
aw damn I guess ill have to wait for the crawl masters.good luck with the build
06-07-2007, 09:05 PM | #17 |
06-07-2007, 09:11 PM | #18 |
06-07-2007, 09:14 PM | #19 |
Whew, probably not........6 1/2 hour drive for me........I swore off FOTO anymore and its ony 5 hrs.
06-07-2007, 09:46 PM | #20 |
Rock Crawler Join Date: Jul 2006 Location: Olympia
