12-28-2007, 09:17 AM | #1 |
Newbie Join Date: Jul 2007 Location: Rome- Italy
| From PVC to Piston Cane
Experiments are going on....after a brief digression with PVC Pimp Cane (a.k.a. PV-Cane), never tested on ground (just a short run in my living room, going up and down on my sofa ), I've built another Clod chassis, something between a Pimp Cane and a Stick. The idea has been that of a very simple chassis, like the Pimp Cane is, but where the twisting is not obtained through aluminum elasticity but, instead, in a more Stick-like fashion. However, instead using some links and shocks (like the original Stick design), I've chosen a different and simple approach, using a big spring joining two cylinders, attached to the axle housing, and inside of which an aluminum bar is inserted to stiffen the chassis and allow the twisting. Here a picture To be noted that the sping work in 3 different way: through its torsion, allowing twisting; through its compression and extension, giving some shock absorbing capabilities. More pictures are here As you can see, either the twisting and the clearance are very wide. To make better tests, I'm waiting for a springs set of different wire size and pitch. Hopefully, some real tests will be made in the next few days. Bye. |
12-28-2007, 09:38 AM | #2 |
Rock Stacker Join Date: Jan 2007 Location: Spain -> Granada
Good idea!!! You only have to test it on rocks to confirm the good performance. i seem that the spring is joined with glue strap, you don't have slide with the both axle of the chasis |
12-28-2007, 09:55 AM | #3 |
Adilynsdad too! Join Date: May 2004 Location: G ville
Does the wheelbase change during compression?
12-28-2007, 10:22 AM | #4 |
12-28-2007, 10:23 AM | #5 |
Just curious as to if this would be comp legal with the adjustable wheelbase?
12-28-2007, 10:47 AM | #6 | |
Bye. | |
12-28-2007, 10:49 AM | #7 | |
Cool design, none the less | |
12-28-2007, 01:19 PM | #8 |
damn i like it! should be an even lower CG than the stick. due to the 1/2" lower back bone, and lack of shocks. |
12-28-2007, 04:36 PM | #9 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
I would try to limit the flex a bit.
12-28-2007, 06:49 PM | #10 |
yeah if the flex was limited to 70 degrees or less and it s predictable then it should be pretty successful.
12-28-2007, 10:42 PM | #11 |
Hi, at moment the only way to limit the twist is to use a more stiff spring (I've ordered a couple of them). The challege is to find a kind of full-stroke-lock mechanism without compromise the whole design cleanness Bye |
12-28-2007, 11:06 PM | #12 | |
Running droop,your WB will be shorter on full droop. Running all up travel,your WB will be longer at full bump. Last edited by Reflection; 12-28-2007 at 11:10 PM. | |
12-28-2007, 11:32 PM | #13 | |
RCC Addict Join Date: Nov 2005 Location: Utah
He is correct. When i ran full droop my wb would shorten a 1" This rig looks awesome! If you could get that spring dialed so you could only flex like 75 degree youd be set. | |
12-29-2007, 02:18 PM | #14 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
boingoingoingoingoingoingoingoing
12-29-2007, 06:50 PM | #15 |
RCC Addict Join Date: Mar 2006 Location: Xxx
| That is super cool !!! All I would say is remove the skid plates . You might get a few more inches of ground clearence. |
01-19-2008, 12:09 AM | #16 |
Well, after some tests I've made some changes. First, I've mounted a stiffen spring (10mm length, 2,5 wire size) so that the twisting is now less wide than before (however it is important to remember that on a Pimp Cane or Piston Cane the twisting is not limited by a some mechanical part, like for example the full stroke of a shock - the only limit is given by the elasticity of the material: aluminum for a Pimp and the spring for the Piston) Then I've moved all the electronics on the axles, to have less pieces on the chassis (so it will be easy to change it on the field) and now I have one battery for each ESC (yes, I will probably have different discharge time, maybe the back battery first due to the higher load of the motor, but considering that with my Axiom 85T I should have hours of autonomy, I reckon that this is not a real problem...) New body mounts has been made (not an easy task using a tubolar chassis that cannot be drilled) and a PVC plate has been mounted just under the chassis to protect the spring and to cross obstacle easier. Here some pictures: Hope to do some further test in the next days. Bye |
01-19-2008, 12:32 AM | #17 | |
Rock Crawler Join Date: Jul 2006 Location: Olympia
Your wheelbase would be longest when the (lower) links are level. If your compression goes to the point past that you would actually be shortening your wheelbase at both "bump" and "droop".......Since this is tech. On that note I didn't pay much attention but is there actually a rull saying you can't have adj. wheelbase in Super? or is it just 2.2. Of course I'm about to go look. | |
01-19-2008, 02:49 PM | #18 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
IIRC, the rules say that the truck must finish the course with the wheelbase it started with.
01-19-2008, 03:00 PM | #19 |
Quarry Creeper Join Date: Dec 2006 Location: dot com
01-19-2008, 04:11 PM | #20 |
Pebble Pounder Join Date: Jan 2008 Location: Michigan
Hmm, this is very interesting. I could see this becoming an awesome chassis/stick.
