Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Tamiya CR-01
Thread: Goat in CR-01
Old 05-27-2008, 12:05 PM   #1
Default Goat in CR-01
Just wondering if anyone is using a Novak Goat in their CR-01.
I have a goat in my axial and am wondering if the stock gearing on the Tamyia would need to be changed.
I am getting ready order my CR-01 and need to make a decision on the motor.
Takoba is offline   Reply With Quote
Old 05-27-2008, 12:29 PM   #2
rbl
rbl's Avatar
cartronicshn's CR 01 Fjwacker Honduras style
he did^^
rbl is offline   Reply With Quote
Old 05-27-2008, 01:11 PM   #3
I do, brakes are incredibly strong, will nose over if your not carefull. Takes getting used to.
I have a 18m tooth Robinson Racing pinion in it, stock tamiya was 20m. I think it still is to fast and could be a good 2 teeth smaller.
Remember if you change pinions, this spur requires is a "metric pitch" pinion. If you put a standard 48 pitch in you'll eat gears.
william g is offline   Reply With Quote
Old 05-27-2008, 06:02 PM   #4
Thanks for the replies.
I think I am going to go with the goat.
It looks like the Goat can wreak havoc on the drive lines.
Any suggestions for beefier drive lines for the CR-01?
Old 05-27-2008, 06:05 PM   #5
Never mind.
I just read the thread on the Jato shafts.
Old 05-27-2008, 06:10 PM   #6
Forget the Jato shafts. Since you're going "balls out", get these...
http://rc4wdstore.com/product_info.php?products_id=822
Big_Lumpia is offline   Reply With Quote
Old 05-27-2008, 06:33 PM   #7
Paypal....arghhhh!!
cartronicshn's Avatar
Originally Posted by rbl View Post
Yup i did, take the suggestions on the beefier driveshafts also
cartronicshn is offline   Reply With Quote
Old 05-27-2008, 09:33 PM   #8
i agree on the driveshafts also. 2 battery packs and both of mine are already twisted a little
icewake is offline   Reply With Quote
Old 05-28-2008, 09:37 PM   #9
crcoppens's Avatar
I run a goat and it is great, although as an earlier poster said, you need to watch the braking as it will just about flip over if you brake too hard.
crcoppens is offline   Reply With Quote
