07-11-2008, 12:23 PM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: SWEDEN
| First Crawler CR-01
My first post here so Hello u ppl My name is Peter and i live in north of sweden. Heres my question. Getting a Cr-01 soon and wanted to know if anyone has any guide/howto to add a second steering servo to it in the rear . What parts i need and would be nice with pics showing. Thx. Peter |
07-11-2008, 12:42 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
Wait until you get the CR01, the same parts you use for the front for steering are the same ones you will need for the rear.
07-11-2008, 04:38 PM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
All you need to buy is a second servo for the rear steer...all the needed parts are included in the kit...
07-11-2008, 10:54 PM | #4 |
Rock Stacker Join Date: May 2008 Location: Cupertino
I just ordered mine too. Don't you need a servo reverser for the second servo to work?? DDT |
07-12-2008, 01:02 AM | #5 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
Youll allso need 3 or more channel radio ,dx3 (but not dx3.0)etc
07-12-2008, 01:06 AM | #6 |
If you use a Y-harness+servo reverser, you only need 2ch.
07-13-2008, 09:31 AM | #7 |
Ordered it now. Are there any parts that i should order for it straight away ? I want more pinions so which pinions works for this one? Never had a tamiya before so dunno what pinions they use.? Are they 3.2mm or other ? Which pitch do they use ? Going to use my 2.4Ghz spektrum and castle sidewinder esc in it. Also adding the Punk Rock Crawling computer just to try it out. Peter |
07-18-2008, 09:57 AM | #8 |
Ordered a bunch of alu parts for it as well as some spare tamiya parts. Also ordered 2 15kg servos that will work fine. Did a small test with the PunkRC computer with some old servos and works really nice. Cant wait to install it in the truck when it arrives. The car u see in the vid is just because i didnt bother taking the servo off so used that servo with the loose one i had Here´s the VIDEO |
07-18-2008, 01:06 PM | #9 |
Quarry Creeper Join Date: May 2008 Location: Franklin
Buy the traxxas hardened output shafts and drive shafts. You will have to short one shaft though. Plus a better set of shocks. Other than that read this thread From the Land of Sky Blue Waters.... It gives alot of good suggestions.
07-18-2008, 02:42 PM | #10 |
Quarry Creeper Join Date: Aug 2005 Location: newport
| Tamiya metric pitch, same pinions as used on most of Tamiya's sedans. |
07-19-2008, 12:52 PM | #11 |
Is the tamiya motoraxle 3.2mm or other ? Ordered the Novak 55 aswell and it uses 3.2mm and wanna know if i can use the same pinions on them both.
07-25-2008, 11:16 AM | #12 |
I have mine built and really happy with it so faar but i have a small problem. When i am crawling in places where it flexes alot the rear wheels keep rubbing to the body where the lights are as shown in the pic ? I like to have alot of flex but not so much that i have to modify the scale body. Any Ideas ? Doesnt rub agains the body in the pic but u see what i mean. |
07-25-2008, 11:29 AM | #13 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
There's a couple of options, trim th body higher, raise the body even more, get a longer wheel based body. I got the proline bushwacker body works good for 2ws, but as soon as I added the 4ws ,the rear hits the body when turning, I gotta trim it to clear, as for the orginal body I have a lighting kit in the works that uses the 3rd channel so I wont have that issue. |
08-16-2008, 03:48 PM | #14 |
"Trimmed " the body abit Its just roughly cut so faar and will cut it the right way soon. Going with this style when its done but with a soft top. Trying out the Recaro seats..... |
08-16-2008, 04:34 PM | #15 |
Quarry Creeper Join Date: Apr 2008 Location: sanford
i like so far |
08-16-2008, 05:45 PM | #16 |
Newbie Join Date: Jun 2008 Location: Tulsa
check out my cr01 porn thread, i am currently doing something similar
08-18-2008, 10:39 AM | #17 |
Body is cut to the way i like it and new rear bodyposts mounted. You wont be able to see those posts after i have put the sparetire or the jerrycans back there |
08-18-2008, 12:20 PM | #18 |
Started building the rollcage now and waiting for styrene and other bits to arrive. Also waiting for new Alu rims and wheels.
08-19-2008, 10:07 AM | #19 |
Started making the interior abit with paper and making the real thing with styrene when it comes in the mail. The floor will be completly flat with a centerconsole to hide cables. Also making dashboard and other later. i am not 100% sure about the height and position of the chair but will figure that out later or maybe u have some input?. |
