02-04-2014, 10:55 AM | #1 |
Newbie Join Date: Jan 2014 Location: Fayetteville, PA
| Looking for suggestions/advice on ESC
I recently picked up the RTR Land Cruiser CR-01 from Tamiya's scratch and dent sale. I know I cheated by buying it already assembled but I'm actually itching to build a kit, hopefully with my kids. Onto my questions. The kit came with Tamiya's 302BK ESC along with their old school FM tx/rx. I already have a DX6i that I'm using with my Summit so I'll more than likely use that with this as well. I do however want to swap out the stock Tamiya servo with either a Traxxas 2075 or the Hitech HS-5645MG. I know the 2075 is waterproof but from what I understand the 5645MG is not? I won't be submerging thiis thing but we have had plenty of snow this winter so chances are it will be doing a little snow running. So, my main question is will I have any problems using either of those servo's with the Tamiya ESC? The specs of the ESC are: Length: 1.3" (33.5mm) Width: 1.1" (27.2mm) Height: 0.6" (14.3mm) Weight: 1.7oz (48g) with wires Weight 1.5oz (43g) body only Control System: High frequency wave drive Max Continuous Current: (FET spec) Forward 120A, Reverse 60A Power Supply: 7.2V - 8.4V (6-7 cells) Compatible Motor: R/C car motor over 23 turns Driving Frequency: 500Hz, 1kHz, 2kHz (with three steps) Receiver Output Voltage: 6V (input 7.2V) Receiver Output Current: 1A If this ESC doesn't look promissing, what are some other reasonably priced alternatives? Thanks! |
02-04-2014, 02:45 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Looking for suggestions/advice on ESC
You should be good if you use an external bec. The 5645MG is not waterproof, however it's a very good servo. You can wp it yourself. And if you plan on using a lipo battery with this esc, your max is a 2s and you will also need an external low voltage alarm so you don't run the battery voltage down too far. The Holmes Hobbies BR-XL would be great alternative if you choose.
02-04-2014, 04:57 PM | #3 |
Thanks for the reply! I have another question, if I were to go with the 2075 Traxxas servo, could I use the metal horn that is from the Hitec servo, this one: TowerHobbies.com | Hitec Standard Metal Horn 3/4" Single Sided |
02-04-2014, 05:25 PM | #4 |
Quarry Creeper Join Date: Sep 2011 Location: Lexington
X2 on the BRXL, I run one in all my rigs. Negative on using the Hitec servo horn on the 2075. You'll need a 25 tooth horn, futaba is compatible I believe.
02-04-2014, 07:46 PM | #5 |
Thanks Duxx! I'll start searching for a horn for the 25T. I think I read on here that it needs to be around 3/4" long.
02-05-2014, 07:38 AM | #6 |
I was eyeing that up on the scratch and dent sale. Already have 2, but what the heck. I run a TRX 2075 on the stock Tamiya ESC with no issues. I think that 1 amp number is a bit on the conservative side, as I run HiTech 645MG's too and don't notice any problems. Try it first, if it browns out on you, then upgrade to a BEC. Yes, Futaba horns (25 spline) fit Traxxas servos. X2 on the LVC on the ESC, Tamiya ESC's include a low voltage cut-off, but it is for LiFe batteries, the cut-off is too low for Lipo batteries. |
02-05-2014, 07:55 AM | #7 |
I actually decided to go with the 2075 servo for now and found a good deal on the XL-5 ESC so I'm going with that. The only thing I'll have to do now is switch out the connectors on the extension piece for the TLU-01 lighting unit. I also picked up a waterproof receiver box from a Slash after seeing that set up on EeePee's rig.
03-06-2014, 12:01 PM | #8 |
Pebble Pounder Join Date: Nov 2013 Location: Bedford, Nova Scotia, Canada
The only thing I would caution about the Traxxas 2075 are the plastic gears. I've gone through a few sets of them, although I will admit that was on a Summit, which will put any steering servo to the test. Of course, on a CR01 they may be fine. I got a Savox 0231mg waterproof servo (with metal gears) for mine. Unfortunately, with this servo the stock "servo bumper" won't fit, and believe me I tried!
03-13-2014, 06:40 AM | #9 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
How about this....solves all issues, it is waterproof, has metal gears, has decent torque and is a little smaller than the SW0231. Savox SW0230MG HV Waterproof Digital Servo Last edited by HDMM; 03-13-2014 at 06:44 AM. |
Looking for suggestions/advice on ESC - Similar Threads | ||||
ESC suggestions | rockhound | Electronics | 5 | 09-04-2012 01:34 PM |
suggestions for a ESC please have a look | TRAV | Electronics | 6 | 08-30-2012 10:28 PM |
Need ESC suggestions | mudboggin3 | Electronics | 2 | 08-06-2012 12:49 PM |
Motor and ESC suggestions | painter4x4 | RC4WD Trail Finder 2 | 5 | 06-23-2012 08:12 AM |
ESC Suggestions | nsg1rc | Newbie General | 8 | 10-16-2009 10:12 PM |
