03-30-2015, 11:30 AM | #41 |
| Re: 3Racing CR-01 - Land Blinger |
04-08-2015, 10:35 PM | #42 |
Rock Stacker Join Date: Apr 2009 Location: Auckland, NZ
How are you finding the HobbyWing ESC? I've installed one in my CR-01 as part of my upgrades but wonder whether I'd get better braking from a different ESC? Thanks Richard |
04-09-2015, 02:13 PM | #43 | |
| Re: 3Racing CR-01 - Land Blinger Quote:
I haven't had a chance to run this CR-01 with the HobbyWing ESC. The CR-01 is heavier than my other rigs so it might get hotter, but with correct gearing I don't see it ever being an issue. The only drawback of both the HobbyKing and HobbyWing ESC's are that the drag brake is nonadjustable. But its setting is pretty good for my rigs. | |
04-09-2015, 03:39 PM | #44 |
I think, from reading other posts, I've realised my error with the 1060 in my CR-01. I've not had the drag brake on. Being reasonably inexperienced in these things, I'd assumed that having the jumper in the f/b/r slot gave me drag brakes. However, I now understand that I need the f/r mode for the brakes (which is remove the jumper altogether). I'm taking the car out later, so will see how I get on. Thanks, Richard |
04-09-2015, 08:02 PM | #45 | |
Let me know how you like it with drag brake. | |
04-09-2015, 10:05 PM | #46 |
Took the car to some challenging slopes today (a place call Pigeon Mountain; one of Auckland's many volcanoes). Steep, jagged rocks with some soil between and lot of very slippery pine needles. Plenty of need to pause on climb and descent...the drag brake was great.
04-10-2015, 06:42 AM | #47 |
Got all three of mine ready to go for the weekend, it's on! The Touerag just got a new pair of shoes and possibly new shocks if I get time to do so. Taking yours out this weekend? |
04-10-2015, 07:42 AM | #48 | |
Nope. Unfortunatley, the CYS servo from Crawford Performance Engineering broke during the first test run in the house. I contacted them numerous times at least 2 weeks ago without response so I finally filed a PayPal claim. I have to replace the servo before I can drive it. I think I'm taking my second Sawback out this weekend. I haven't driven that yet either. | |
04-21-2015, 08:16 PM | #49 |
Rock Stacker Join Date: May 2014 Location: Ontario
Hey Jato - where did you get that box of screws you have by the frame rails in on the first page of your build? D |
04-28-2015, 10:37 AM | #50 |
| Re: 3Racing CR-01 - Land Blinger It's a stainless steel screw kit for the CR-01 from a company that I won't mention. You can see the label in one of the pictures though. But I wouldn't recommend the kit. There were 4 different sizes of screws that were the wrong length. I contacted the owner and he was extremely rude. He sent me some of the screws, but told me to cut the one size down to correct length. He insisted it mentioned this on his site, but I looked everywhere and couldn't find it. When I questioned him about where this was mentioned on the site he ignored me.
04-29-2015, 08:13 PM | #51 | |
Good job on your build, it looks great! D | |
05-12-2015, 10:04 AM | #52 |
Rumor has it this truck made an appearance at a night run... how'd it run?
05-13-2015, 05:18 PM | #53 | |
It crawled really well for being a maiden run! I was so happy with it. It wasn't nearly as top heavy as it looks. In fact, it was pretty darn stable. The front to read weight balance is pretty good too. The only thing I didn't like is that the links seemed to drag early and hinder the performance. I bought the Tamiya bent links to try. | |
05-21-2015, 08:36 PM | #54 |
Is there any way to overdrive/underdrive the axles? I'd like to try this for the first time. I'm also considering buying the aluminum axle housings for this to complete my aluminum look, but to mostly get some additional weight down low. |
05-25-2015, 07:19 PM | #55 |
I know of no way....TLT and F350 gears are the same size. RC4WD might have some older ones that fit, but I have no idea which they would be (and it's a pricey gamble) I think the aluminum axles are the only thing I haven't bought. |
05-26-2015, 07:57 PM | #56 |
06-15-2015, 12:28 PM | #57 |
I took my CR-01 to Lake Nockamixon and my dad took his Dingo. My truck performed well, but it's a little top heavy (which I expected with the tall ride height and tall body) and it flips over backwards on climbs easier than I want it to. Any suggestions on how to fix this other than stuffing more weight in the wheels? I know that would help with both, but I don't want and even larger weight bias in the front because then it will flip forward on downhills. Inexplicably I broke a metal, Tamiya driveshaft, or prop shaft as they call it. This was only the third run on the truck. I dont understand this breakage at all. I've never broken a plastic Axial driveshaft, a plastic GMade Sawback driveshaft, or the metal Junfac driveshafts on my other Sawback. This is crazy. Photos below. 06131513040613151315a0613151320b0613151427 The carnage: 0613151446a 2WD Crawling from here on out on this trail run. 0613151455b0613151511b 2WD Hill Climing 0613151523a06131515220613151521c Last edited by JatoTheRipper; 06-15-2015 at 01:03 PM. |
06-18-2015, 07:25 AM | #58 |
Move your rear upper links up...I see they are mounted in the lowest holes on the chassis side. You're getting a lot of leverage there from the chassis.
06-18-2015, 09:39 AM | #59 |
That's a good point! Thank you!
07-13-2015, 04:06 AM | #60 |
Newbie Join Date: Jul 2015 Location: Sydney Australia
Since joining this forum and looking at your rig I have had 2 or 3 sleepless nights tossing and turning murmuring to myself, "Need Bigger Tyres, I neeeeed Bigger Tyres" Looks absolutely awesome!!!!!! One of my favorites I have come across on here so far |
3Racing CR-01 - Land Blinger - Similar Threads | ||||
15 trucks Offroad: Sniper Land Rover D90 D110 Ford Land Cruiser Trail Finder 2 Dingo | boolean21 | Scale Videos! | 0 | 08-30-2012 07:48 AM |
12 trucks Mudding! Land Rover Honcho Land Cruiser Dingo D110 RSOV Wraith King Hauler | boolean21 | Scale Videos! | 0 | 07-16-2012 06:27 AM |
My flat land LAND ROVER | seabeejeep | 2.2 Scale Rigs | 3 | 08-11-2010 10:35 AM |
hard jeep/land cruiser/land rover body | IronRC | Paint and Body | 2 | 03-02-2008 10:14 PM |
