07-13-2015, 08:49 AM | #61 |
| Re: 3Racing CR-01 - Land Blinger Thank you!!! That means a lot. |
07-13-2015, 04:30 PM | #62 |
Since I had to replace the front driveshaft on this truck, I figured I'd add the Tamiya bent links while I had it apart. I have never used bent links on any rig, but I think this truck will benefit from them. I noticed the links hitting often despite this being a short wheelbase truck with large tires. Per OSRS's advice, I also moved the upper, rear link link towards the top of the chassis plates. My goal is to prevent the truck from pivoting over backwards when climbing uphill. I also moved the lower, rear link back one hole to extend the wheelbase. In this picture the bent links are installed in the front and the rears are still stock. You can see I have gained clearance. 0711151948a Both links installed. The links are almost parallel to the skidplate. 0711152154a Both links installed with the body on. I gained some length by moving the rear link back, but I also gained some interference with the body. I'm going to run it and see how bad it is on the trail 0711152116a |
3Racing CR-01 - Land Blinger - Similar Threads | ||||
15 trucks Offroad: Sniper Land Rover D90 D110 Ford Land Cruiser Trail Finder 2 Dingo | boolean21 | Scale Videos! | 0 | 08-30-2012 07:48 AM |
12 trucks Mudding! Land Rover Honcho Land Cruiser Dingo D110 RSOV Wraith King Hauler | boolean21 | Scale Videos! | 0 | 07-16-2012 06:27 AM |
My flat land LAND ROVER | seabeejeep | 2.2 Scale Rigs | 3 | 08-11-2010 10:35 AM |
hard jeep/land cruiser/land rover body | IronRC | Paint and Body | 2 | 03-02-2008 10:14 PM |
