01-15-2016, 12:32 AM | #1 |
Newbie Join Date: Oct 2015 Location: Lancaster
| Pinion problems?
I know on some Tamiya models they recommend replacing the kit pinion with a steel one as the stock aluminium item is soft and wears quickly. Is this the case with the CR-01 kit pinion or is it harder wearing? Sent from my iPad using Tapatalk |
01-16-2016, 08:07 AM | #2 |
| Re: Pinion problems?
I've got all my pinions since I bought mine new (have 3) Same metal stock as all the others. It is interacting with a nylon gear and it's pretty durable in that scenario. Keep it greased up and check it every few months. Tamiya gearboxes are generally very tough. I'm had some wear out after a while, but it takes a good long while to do so. I've worn out the rear ring and pinion one one of my CR01's well before the pinion. |
01-23-2016, 10:24 PM | #3 |
Quarry Creeper Join Date: Jan 2010 Location: vancouver, canada
i agree, there are many different "weak links" within the drive train that will fail before the pinion/spur connection.
01-24-2016, 12:34 AM | #4 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
X2. I've been running mine on 3S with no issues other than one rear ring/pinion.
02-04-2016, 07:12 AM | #5 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
Pretty much the only Tamiya pinions I had wear issues with were the ones on dual motor setups, (TLT, Juggernaut).
Pinion problems? - Similar Threads | ||||
Ring and pinion problems | gottorque | Venom Creeper | 43 | 10-07-2014 05:55 PM |
Just went out to the track for the FIRST TIME. Problems Problems Problems | flyingrc | Non Crawler RC's | 4 | 07-23-2012 10:19 PM |
Problems problems problems hope it's worth it in the end | TJcreeperJEEP | Venom Creeper | 9 | 12-22-2009 04:54 PM |
ARTR Pinion problems? | MuddyOval | Axial AX-10 Scorpion | 4 | 06-26-2009 07:45 PM |
Pinion problems-need sudgestions! | Highmark | General Crawlers | 2 | 03-30-2005 06:23 PM |
