12-26-2016, 05:06 AM | #1 |
Newbie Join Date: Oct 2015 Location: Lancaster
| Reinforced diff lock assembly, item 54108
Hi, The threads in the original diff housing stripped after I'd had the front diff locked and used it on a too grippy surface. So I purchased the reinforced drive shaft and diff lock hop-up option parts (item 5410 and a new diff housing. I've finally got round to assembling it this morning only to find it doesn't go together very well. The tolerances must be out or something as the part labelled "Diff lock B" will not fit the recess in the original housing. Has anyone else any experience assembling these parts? Dave. Sent from my iPad using Tapatalk |
12-26-2016, 07:22 AM | #2 |
| Re: Reinforced diff lock assembly, item 54108
I've built 4 of them, all of the went together perfectly. If i remember correctly, I bolted parts A and B together, then put the assembly into the housing. That part is a snug fit, but I don't recall having to force it in any way. Might have to see where it is interfering and do a bit of work with a file. It will be worth it - all the slop will be gone when you get it installed. |
Reinforced diff lock assembly, item 54108 - Similar Threads | ||||
CR01 Reinforced Drive Shaft - w/Diff Lock | DaveGT | Tamiya CR-01 | 1 | 10-23-2016 11:57 AM |
Need help with bead lock wheel assembly. | 68_f100 | RC4WD Trail Finder 2 | 5 | 08-31-2014 11:06 AM |
Need help with bead lock wheel assembly. | 68_f100 | RC4WD Trail Finder 2 | 3 | 08-30-2014 07:34 PM |
Lock Snot, Diff lock | JohnRobHolmes | General Crawlers | 10 | 09-29-2007 05:54 PM |
