05-23-2006, 09:42 AM | #1 |
Rock Crawler Join Date: May 2006 Location: Georgia
| my brushless SW2
specs SW2 chassis with pede trans locked with JB weld. locked TLT axles. holmes hobbies revolver brushless motor, mamba 25 esc. JR ST125mg servo 7 cell GP1100 pack originally built for an AE RC18T. 87-12 gearing stampede sliders and yokes. Maxx shocks with 20wt oil, 35wt in right rear shock losi yellow 2.0 rate springs with half a coil cut off. 12.2 wb and 3 inches of ground clearance total running vehicle weight of 4lb 5oz Stampede wheels with Moab tires Rubicon body Blackfoot Axles I just finished building this truck this morning. I have only had it out once and so far im really happy. Run time was about 25-30 minutes but this pack was charged about 3 weeks ago. Also a short vid hope it works.http://s20.photobucket.com/albums/b2...Picture012.flv Last edited by JasonInAugusta; 05-23-2006 at 09:45 PM. |
05-23-2006, 09:50 AM | #2 |
Im also running stock foams on unglued tires with no wheel weights.
05-23-2006, 12:21 PM | #3 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Nice work, I love the way that motor looks in the chassis.
05-23-2006, 12:29 PM | #4 |
Welcome to the Revolution!:-P Looks good! |
05-23-2006, 01:08 PM | #5 |
RCC Addict Join Date: Jul 2005 Location: Provo
you should really narrow those wheels it'll look 1000times better...thats sweet:-P
05-23-2006, 02:13 PM | #6 |
RCC Addict Join Date: Apr 2006 Location: On Da' Shelf
Wow that is nice! any link to that bl motor? how does it do for crawling? and how does the mamba esc run in this setup? does it run hot or warm? thanx for any info! |
05-23-2006, 03:32 PM | #7 |
Pebble Pounder Join Date: Apr 2006 Location: Spring Hill, TN
What is the Traxxax part number for the Maxx shocks? Thanks! |
05-23-2006, 08:36 PM | #8 |
xtant here is some info on the motor.Outrunner Brushless in stock, esc's too temps have been around 120 max with the motor and 100 for the esc and batt. I have been folowing your build thread on 1/18th. 18th scale is what got me back into RC 1.5 years ago. If you already have the mamba 25 like i did. I would recommend ordering a motor for it. You will be impressed. lowandslow these are the shocks im running http://www2.towerhobbies.com/cgi-bin...&I=LXJK80&P=ML thanks for all the input |
05-23-2006, 11:16 PM | #9 |
Lookin good man! It seems to articulate well, even with the lighter electrics. Must be the Bender chassis' adjustablility with shock mounts. How peppy is it with your gearing and 7 cells? I bet it is pretty zesty! |
05-24-2006, 07:17 AM | #10 | |
Im loving the motor. I think it is geared just right with my pack. It will creep slow enough to go over anything, and when I say slow I mean slow. At full throttle it is faster than walking speed. | |
05-24-2006, 08:41 AM | #11 | |
Truck looks good, glad to see this brushless thing starting to catch on | |
05-24-2006, 04:27 PM | #12 | |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
05-24-2006, 04:51 PM | #13 | |
Who told you brushless would work in a crawler?!? They are wrong!! | |
05-24-2006, 05:03 PM | #14 |
Newbie Join Date: Dec 2004
| More info on the motor?
Can you give us some specs on the motor? How many Watts? How many RPM per volt? Thanks.. |
05-24-2006, 05:55 PM | #15 | |
Follow the link in my sig Watts- around 1/4 horsepower K/V- 1000 It packs plenty of grunt for a crawler. | |
05-24-2006, 06:06 PM | #16 |
Rock Crawler Join Date: Jan 2006 Location: Nebiru, OuterSpace
its around 1000kv... so if you're all geared up for a 55t lathe... then the JRB's Revolver should also be JUST right on the mark for your gearing setup. i have a TLT with 55t lathe and a PTI with JRB Revolver... i the revolver rig is just better. goes faster on top speed (not geared as low as TLT), but has plenty of NO stall power despite the higher gearing. matter of fact snapped a HPI thick dogbone in the axle on the PTI the other day (RATS!!!). just too much power in the Revolver... love every minute of it!!! |
05-24-2006, 07:12 PM | #17 | |
05-24-2006, 07:36 PM | #18 |
Brushless provides SO much more power! Once you try it, you won't go back! The Grunt is a different crawler w/ the power it now has available. Last edited by dezfan; 05-24-2006 at 07:53 PM. |
05-24-2006, 07:48 PM | #19 | |
05-24-2006, 09:55 PM | #20 | |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
