06-13-2006, 09:04 AM | #1 |
Pebble Pounder Join Date: May 2006 Location: Abington
| my new tlt
well i just recently got my tlt and after building it and driving for a while i decided to start the modifications. before: after: i currently have 2ws with locked diffs all around. the shocks are hot bodies threaded t/e maxx shocks. i took the tire from a stampede and the motor is the stock silver can. what should i do next? |
06-13-2006, 09:06 AM | #2 |
Drive it until you find it's weakness.
06-13-2006, 10:40 AM | #3 |
alright so i went out and did some driving today and found a problem. the chassis moves side to side about 1.5-2 inches. how do i fix it? |
06-13-2006, 10:44 AM | #4 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
try setting your upper links to the middle of the axle about where the servo mounts. Edit: or just buy the Vertical Smile and send me the axles and I'll set it up for you |
06-13-2006, 11:31 AM | #5 |
Yep you need to move your upper links. Need to look like this \/
06-13-2006, 11:50 AM | #6 |
Quarry Creeper Join Date: Jan 2006 Location: Winston-Salem
Sounds like a torque twist problem. Search for torque twist under seatrch button. Good luck.
06-13-2006, 01:30 PM | #7 |
Rock Crawler Join Date: Sep 2005 Location: wyckoff, NJ
triangulation is key
06-13-2006, 01:55 PM | #8 |
Yeah... those upper links need to be triangulated. Torque twist is something completely different...
06-13-2006, 02:05 PM | #9 |
yea i kinda figured that. i'm working on getting some upper link mounts to triangulate the links. thanks for the help.
06-13-2006, 02:53 PM | #10 |
06-17-2006, 09:27 PM | #11 |
well i found an easy way to fix my problem, move the upper links to the inside of the chassis. it was that easy. now i can make it into the scale rig i was planning on. here's the build: my new project Last edited by clodman666; 06-17-2006 at 09:48 PM. |
06-17-2006, 09:54 PM | #12 |
Rock Crawler Join Date: Jan 2006 Location: In the basement
Try to lower your CG a bit. That will help.
