07-20-2006, 09:01 AM | #41 |
look what i just recived in the mail , guess who's loosing the carbon fiber chassis |
07-20-2006, 09:06 AM | #42 |
Now thats a pretty site. You should be proud to have such a great product. Good luck |
07-20-2006, 09:34 AM | #43 | |
RCC Addict Join Date: Mar 2006 Location: Bedias, Texas
Hello Carlos, Glad to see that you received everything okay. You'll be going down unchartered territory as all the other builds have been 12.5" and your is going to be 14". I look forward to seeing just how it works out. Just a thought, your shocks are not going to reach your axles so you're probably going to have to attach them to your links. Maybe something like this would work. Anyway, can't wait for you to start the build. | |
07-20-2006, 09:38 AM | #44 |
If you attach them to the links you may have alot of torque twist. So I have heard.
07-20-2006, 10:24 AM | #45 |
any suggestions , if i run into torque twist, where should i attach them?
07-20-2006, 10:27 AM | #46 |
Make some upper shock mounts that relocate the shocks or try longer shocks.
07-20-2006, 10:43 AM | #47 |
o yes, the stock shocks are history, i have a set of maxx shocks on the way , also have a set of integy's on standby, you think 4" will long enough
07-20-2006, 11:01 AM | #48 |
some progress , this was the real easy part |
07-20-2006, 02:28 PM | #49 |
Carlos, Your easiest solution for mounting shocks may well be to just get yourself 4 Savage shocks. They should be just about the right length to work with your setup and attach to the axles. |
07-20-2006, 02:34 PM | #50 |
i just ordered a set of savage shocks, also i had to redrill the axle mounts the holes didn't quite line up , i know it is a prototype, just letting you know |
07-20-2006, 02:39 PM | #51 |
You type to fast man. They will be on your way shortly.
07-20-2006, 02:48 PM | #52 |
i love fast , the truth is that i have like 4 more unfinished projects, so i have finally decided to make it only 3 lol |
07-20-2006, 04:18 PM | #53 |
some more work done , like i said i had to redrill the link mounts, have some losi shocks mounted, is this what you were talking about run2jeepn and david? for the rear i will deff have to fab some shock mounts as this is 60/40 rig Last picture is of the gutted tlt/penguin chassis Last edited by cartronicshn; 07-21-2006 at 09:33 AM. |
07-20-2006, 05:16 PM | #54 | |
Prototype or not there is no excuse for parts to be miss-drilled like that and I appologize for that happening. Right up front I want you and everyone to know that we do stand behind our product. If you would like a new set of upper link mount plates we will gladly send you a pair on us. As far as your 60/40, 14" setup I can make you a set of custom, rear shock mounts if you would like. Sincerely, David Xtreme rc hobbies | |
07-20-2006, 05:43 PM | #55 |
David i appreciate the offer , awesome customer service , about those shock mounts, pm for details. I'll keep posting, all in all i'am very pleased with the chassis so far |
07-21-2006, 07:23 AM | #56 |
got more or less final stance look , i'am impressed how much longer and sleeker it looks compared to my penguin chassis, it's stands at 13.5" right now ,the center clearance is amazing , i need ideas for shock mounts , i have insatlled in front 3 1/2 losis, but can go to 4" at the back i either need over 5 1/2" shocks, i think i bought a set that are at a little over 6" hope this fit, but i would really like ideas for shock mounting also maybe adpaters for people who migt choose this setup but would prefer 4" schocks all around |
07-21-2006, 07:46 AM | #57 |
There is a way to shorten shocks if you need too. If it comes to that PM me and I tell you how it's real easy. And it can be reversed. Looks good so Far. What kind of body are you going to run?
07-21-2006, 08:22 AM | #58 |
not sure yet i have several 1/10 bodies including the blackfoot, which now with a 14" wb the 1/10 bodies are to small , but the clear ones are hpi 1/8 one is bronco the other is rubicon also the 1/8 truck is always good for bashing |
07-21-2006, 08:28 AM | #59 |
Thats cool. I'm running 1/10th HPI Jeep body on mine. I don't like the over hang. But 1/8 with that wheelbase will look more scale.
07-21-2006, 09:54 AM | #60 |
look what the mailman dropped of , all i need is to finish this project |
