Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: comp style tlt (GROUNDER) with front digg
Old 01-02-2006, 10:57 PM   #1
miniwheeler's Avatar
Default comp style tlt (GROUNDER) with front digg
Chassis, laydown style 050t6 aluminum
tranny, pede
motor, 55turn lathe
wheelbase, 12.5
ground crearance, 2.4
wheels/tires, pede fronts/mashers
wideners, tobee craft 12mm
special feature, front dig
And the poser pic..
miniwheeler is offline   Reply With Quote
Old 01-02-2006, 11:16 PM   #2
pics are too big to view easily. also, posting pics side by side like that make it hard to read...........with that out of the way....
WOW!!!! Looks good! Please enlighten us on your dig setup. How did you make the rear driveshaft disconnect?
cman_1500w is offline   Reply With Quote
Old 01-02-2006, 11:18 PM   #3
Nice rig dude! and YES some info in the setup!
Later,
Jake
JakeDaSnake is offline   Reply With Quote
Old 01-02-2006, 11:32 PM   #4
im still a tard at posting pics dont know WTF i did wrong ,but the front dig was easy i used a tq3 left it stock, the 3rd channel works a hitec hs-81 plenty of power and the driveline is 2 male pedes and a female with the end gruond off the slipper ring in the middle is a maxx shock spacer with 2 more c/a glued on some custom linkage and thats it
Old 01-02-2006, 11:55 PM   #5
The pics are no big deal, just resize all your pics to 640x480 and always post the URL's under each other and not on the same line...
I wanna see the driveshaft in action!
Later,
Jake
Old 01-03-2006, 12:01 AM   #6
Wow, nice idea on how to disconnect the rear end. I'm going to use it now. and nice tlt.
mike is offline   Reply With Quote
Old 01-03-2006, 07:50 AM   #7
FrankyRizzo's Avatar
Really cool idea. I think I might take it a step further by making it cable actuated so it floats with the shaft.
FrankyRizzo is offline   Reply With Quote
Old 01-03-2006, 09:45 AM   #8
hey jim, pictures are looking great! i finally found out what is wrong with the suspension on the scale chevy, hopefully i can get it figured out before the comp!
scott
OIT_TLT is offline   Reply With Quote
Old 01-03-2006, 09:55 AM   #9
Sinking with the ship
1BadJeepBruiser's Avatar
Default Sweet
Truck looks good dude, I dont mean to sound like a DumbASS but what is a "front Dig"? and whats going on with the rear drive shaft?
Mike
Old 01-03-2006, 12:13 PM   #10
Well if I'm not all wrong here I think that font dig means that you can dissconnect the rear wheel drive and make it front wheel drive only.
Jekyll is offline   Reply With Quote
Old 01-03-2006, 01:13 PM   #11
True.
Old 01-03-2006, 01:54 PM   #12
thanks scott for the help maybee i can return the favor and offer some help with you
with yore scaler tlt
jekyll is right,fornt dig allows you to unluck the rear with this you can hook a rock with the rear
and turn on a dime the linkage is part of what makes front dig work
Old 01-03-2006, 03:48 PM   #13
Originally Posted by miniwheeler
....with this you can hook a rock with the rear and turn on a dime the linkage is part of what makes front dig work
Now you need to figure out a setup for rear breaks
Old 01-03-2006, 05:58 PM   #14
hey nice rig. im a little confused on the front dig thingy. do you have any videos on how it works? like how it disconects. any thing would be help full! thanxs!
Luke
mudrinner4ever is offline   Reply With Quote
Old 01-03-2006, 06:40 PM   #15
ive got ideas on how to lock thr rear during a front burn(kinda like a stick in the spokes)i just need to make
it out of better materials kike aluminum and spring steele
I will try to get some video on how it works soon
Old 01-03-2006, 08:05 PM   #16
Awesome man looks good. What type of material did you make your side plates out of? Is it just 16ga. mild steel or is it something else. From the pics it doesnt look too thick.
Other than that sweet truck man, I have been trying to figure out a way to disconnect the rear and lock the rear axle at the same time but might have to do something similar to yours. How does yours act? Have any way to post a quick video of it? Keep up the good work.
Leach
93yjpiece is offline   Reply With Quote
Old 01-03-2006, 08:11 PM   #17
DISTURBIN' tha PEACE's Avatar
From what I can see, the linkage slides the female off the male shaft Is that right?
If so, what keeps the male shaft from falling down? Also, how do you get the splines to line up?
I've been thinking of this & I can't get the re-connection of the shaft down.
DISTURBIN' tha PEACE is offline   Reply With Quote
Old 01-03-2006, 08:23 PM   #18
The chassis is made out of .050 t6 aluminum.
the way its all tied together i think its pretty strong it has taken several big drops with no problems at all
Old 01-03-2006, 09:14 PM   #19
There is an aluminum rod down the center hole of the male shaft that keeps the
2 male parts from falling,when i use the 3rd channel to hook up the rear drive the
servo keeps pressure on it until the shafts line up
like the steering servo tries to turn the wheels but is too weak until the car moves
Old 01-03-2006, 10:08 PM   #20
evo
awesome rig man, you are my hero
evo is offline   Reply With Quote
