08-11-2006, 07:14 PM | #1 |
Quarry Creeper Join Date: Jul 2006 Location: Las Cruces, NM
| "Nothing's Custom" TLT Tracer chassis Part 2
OK, I apologizee for the last thread of similar name. I thought it would happen quick and well, no luck. So here is the start of actual TLT build with stock tranny: Basics: TLT Rock Buster from Ultimate Hobbies for axles --Diffs locked by moving spider gear into spot between other two. Tracer Chassis from Junfac Electronics and servos (All Hitec RCD): 2 – Hitec HS-645MG servos Hitec RCD HFX-R 3 channel ESC with reverse DCX 3 channel Receiver Hitec Aggressor CRX 3-channel Radio bearing kit Junfac Wheel wideners Team Integy 55T motor with 13 tooth pinion gear tires: Moab 2.2 Wheels: HPI super star Body: Proline Ford Courier ------Pic post at http://nothingscustom.blogspot.com/ Last edited by 1tom2go; 09-23-2006 at 02:56 PM. |
08-11-2006, 07:53 PM | #2 |
| The build starts...
The build starts tomorrow, Saturday, morning @ 7am. All parts above are here and User Name and I will start buiding, painting, etc. I will keep you posted. |
08-13-2006, 02:20 AM | #3 |
| All day building
I spent the whole day building with User Name. I got every thing done except mounting the body. For pics of the build go to http://nothingscustom.blogspot.com/ I will give you detail after I sleep. Last edited by 1tom2go; 08-13-2006 at 10:25 PM. |
08-13-2006, 05:15 PM | #4 |
Rock Stacker Join Date: May 2006 Location: Bedford
Looks good. That is the same way i an going to go with mine when the funds come in.
08-13-2006, 09:52 PM | #5 |
RCC Addict Join Date: May 2006 Location: Roseville
Looks good. Did you hit any rocks yet?
08-13-2006, 10:23 PM | #6 |
| Completed build and some tests
Just completed most of the build. The chassis and electronics are put in. The preliminary testing is good. Here's a pic of the first test run: |
08-13-2006, 10:43 PM | #7 |
| Find more pics of the chassis and stuff here |
08-13-2006, 10:49 PM | #8 |
| Body painted |
08-13-2006, 11:07 PM | #9 |
Should get those lower links above the steering knuckle. You will find that as you use your truck in its current configuration, your links will be all banged up. Moving them up will give you a better approach angle and help keep you steering propely.
08-13-2006, 11:36 PM | #10 |
| Hittin' the Rocks Hit the rocks! |
08-13-2006, 11:40 PM | #11 |
| User Names 1:1 and 1:10 |
08-13-2006, 11:42 PM | #12 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
08-13-2006, 11:42 PM | #13 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
Am I the only one that can't see any of these pics?
08-13-2006, 11:43 PM | #14 |
right-click on the image placeholder, select properties, highlight the link and paste it into your browser address bar. It will load that way. Where is that location to crawl? Can I come play? Last edited by Trikster; 08-13-2006 at 11:46 PM. |
08-13-2006, 11:46 PM | #15 |
| My truck looks good but...
Yeah, uhm...the transmission belt started slipping then it got bad. Now it don't climb downhill. User name did not lock his center diff yet, so his slips only a little. We are going to have to modify or customize this TLT tranny. We also have some glitches in the electronics. The trucks jump around some. I am going to have a beer and forget all about it...ok..so I can't stop thinking about it. I guess I better get out the tools. |
08-13-2006, 11:51 PM | #16 | |
08-13-2006, 11:51 PM | #17 |
| Crawl location
Yeah! We just found this spot. I saw some rocks from the road. It is just on the north side of Auburn Outboard Marine along the frontage road. The Penryn exit off I-80 is the nearest exit, then head to the gas station on the south-west side and follow the frontage road toward the boat shop. A little before the boat place is a construction site with a lot of rocks in the back area. Park somewhere and walk in. They wont want us there during the week or in the daytime I'm sure. Have fun! |
08-13-2006, 11:52 PM | #18 |
Robb, go to my blog ste for the pics...look below at the blog site address. Oh, and yes it is a IE thing. sorry man. |
08-13-2006, 11:57 PM | #19 | |
08-13-2006, 11:58 PM | #20 |
The steps I outlined to look at the images work with IE. That is the ghetto browser I am using... I am sure Firefox probably doesn't have that issue. If you need a spare belt or center diff (that I locked with the traxxas slipper pegs, it will still slip if the wheels totally lock) that I am not using. Let me know. Last edited by Trikster; 08-14-2006 at 12:00 AM. |
