08-30-2007, 06:06 PM | #21 |
Well, I have had a good time with this little budget/spare parts build. Here are some pics from the last year: However, I decided on a few upgrades. The list: New set of Red Rocks Junfac Beadlocks Kreepy Squishy Red Foams Custom High Clearance Aluminum Links Bearings in the FR Cs for smooth steering New steering links w/Jato rod ends RC4WD rear lockouts and straight axles Clocked rear axle Stuffed more spiders into the diffs for less play Metal yokes all around On to the pics: (Dont mind the giant cat in the last picture, he just wanted to chew on the antenna) I will have some action shots this weekend. |
08-30-2007, 08:47 PM | #22 |
Interested to hear if the Kreepy's improve the redrocks performance. Truck looks stout with those tires on there |
08-30-2007, 09:30 PM | #23 |
Rock Stacker Join Date: Sep 2006 Location: Big Rapids
Looks mean. That front driveshaft has a bit of an angle to it. Also how are the beadlocks working for you?
08-31-2007, 04:17 AM | #24 |
Not sure how the beadlocks will hold, they have only been tested on the carpet. They are a little weird to setup and kind of difficult to get the bead placed properly. Yeah, the front DS is at a bit of an angle, but there is not really much I can do about that (until someone comes out with clocked Cs). I think the foams work really well in the RRs...they form around objects quite well and rebound nicely. |
08-31-2007, 02:12 PM | #25 |
Clocked Cs...I know I have seen them around. Just not sure where.
08-31-2007, 02:47 PM | #26 |
08-31-2007, 04:22 PM | #27 | |
| Quote: | |
08-31-2007, 07:52 PM | #28 |
Quarry Creeper Join Date: Mar 2006 Location: Manitoba, Canada
regarding the first pics, what the heck is with the beadlocks?? looking very good now though
08-31-2007, 08:11 PM | #29 |
Are you referring to the yellow rims? If so, those arent beadlocks. I bought those tires and rims used and those bead rings were hot glued to the rims. They kept falling off the more I wheeled the truck. Remember, the original build was on the cheap! |
