11-07-2006, 04:10 PM | #21 |
RCC Addict Join Date: Jan 2006 Location: The Amish Ghetto
wow... looks good.... maybe try some short buggy shocks on that to get the pinion angles more managable... tubing is sweet though. |
11-07-2006, 08:09 PM | #22 |
Pebble Pounder Join Date: Jan 2006 Location: Calgary Alberta Canada
X2^.. The pinnion angles are a bit extream I would either run shorter shocks or run the shock mount up to the humps on the top of the frame that way it will correct the pinnion angle and make the whole chassis look more filled. If any one knows what I meen please agree LOL if you don't understand agree anyway and I'll make a diagram of what I meen.
11-07-2006, 09:13 PM | #23 |
Rock Crawler Join Date: Jun 2006 Location: Santa Rosa
so you mean to run the shocks more vertical? Or more horizontal, because i see two humps on the chassis, one that would put the shocks more vertical or the other "hump" would make the shocks lay down more |
11-07-2006, 09:22 PM | #24 |
move to the humps on what would be the hood... farther front on the chassis making them more vertical and then run some super soft springs... |
11-07-2006, 09:50 PM | #25 |
Newbie Join Date: Jan 2006 Location: Edmonton, Alberta
Yeah, I originally had the shocks mounted at the humps as that is what they were put there for. My problem was then I was having clearance issues with the rest of the chassis as I made it a little too narrow. Maybe I'll look at the shockes off of the XX buggy the tranny came from and see if I can work them into the humps. I was a little concerned about the pinion angle as well. I'll see what I can do about it too. i think I have bitten off a little more than I can chew for a first build but what the heck go hard or go home CB |
11-07-2006, 10:04 PM | #26 |
maybe rotate the link mounts down to the belly skid area...
11-08-2006, 12:00 AM | #27 |
Quarry Creeper Join Date: Oct 2006 Location: wollongong, NSW, Australia
it looks great for a first build Shane |
11-08-2006, 10:55 AM | #28 | |
CB | |
11-08-2006, 12:40 PM | #29 |
Pebble Pounder Join Date: Sep 2005 Location: College Station
your probally gonna wanna rock yoru front axle backwards...... with the angle of it now, your tuber wont turn so well.... my $.02 looks real good thought! WTG! |
11-08-2006, 01:11 PM | #30 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
| Quote: |
11-08-2006, 01:19 PM | #31 |
Rock Stacker Join Date: Oct 2006 Location: Courtenay, B.C Canada
Sure the thing is a little out of proportion, but who cares... Most tubers look funny I see a good amount of triangles in there though..looks strong Please hurry and post pics of it when done... |
11-08-2006, 01:20 PM | #32 | |
CB | |
11-09-2006, 05:44 PM | #33 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
I like the chassy but do you really need that much ground clearance, I think it would look and drive 50 times better if you lowered it down to where there was only about an inch drop in your lowers from the frame to the axle.
11-10-2006, 09:30 AM | #34 |
I wasn't going for that much clearance, it has just turned out that way because I have to fix my suspension geometry. I will be moving my links this weekend and trying to get the front shocks mounted back up on the hoops to get the thing down from the stratosphere. If all goes well I should have some updated pics on Sunday. CB |
11-13-2006, 08:54 PM | #35 |
Well I made some progress over the weekend. I got the suspension pretty much sorted out by lessening the pinion angle as well as moving the links closer to the bottom to get the ground clearance down. The only drawback is I ended up with about a 14" wheelbase, which is obviously not comp legal. I won't be competing so I guess this doesn't matter. I also got my driveshafts done and mounted. I found an alternative way to attach sliders to my XX tranny and lock it at the same time without any permanent mods just in case I want to revive my XX. Anyways, enough rambling and on to the pics. Any comments? |
11-13-2006, 09:09 PM | #36 |
Take 3/4" off the rear links and 1 1/4" off the front and I think you will be golden. Even if you aren't going to compete 14" is a little long for those tires. Or get some red rocks, I would shorten it if it were me, killer chassie though.
