Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: NEWB TLT Tuber build
Old 10-23-2006, 10:26 AM   #1
Default NEWB TLT Tuber build
Hi all. Just a newb here that has started to build my first crawler. I figured I would start out ambitious and go straight to building a tuber. I have spent a lot of time on the forum gleening info and studying pictures. Here is what I have come up with so far. I have a long ways to go yet. Opinions and suggestions would be appreciated. I will keep this thread updated with progress pics if anyone is interested. Thanks.
CB
suzukiman650 is offline   Reply With Quote
Old 10-23-2006, 10:40 AM   #2
looks like a good start..nice to see another canadian as well>>..can you give us a list of what other parts you plan on using..
xxkalladorxx is offline   Reply With Quote
Old 10-23-2006, 11:25 AM   #3
Looks like you got something started.
Old 10-23-2006, 11:47 AM   #4
Ya looks like it should be good if you stick with it (my first one is still in pieces that don't really fit together in a box) LOL. But it is nice to see another canadian crawler and your only about 2.5 hours from me (i'm in calgary<<<) Hope we can crawl some time when you get it done.
need some carbon fiber is offline   Reply With Quote
Old 10-23-2006, 01:12 PM   #5
I get to Calgary once and a while for work so I'll have to pack the TLT with me next time and you can show me how to crawl.
For parts I plan to use the following:
TLT axles (obviously)
DIY chassis and links
Losi XX tranny converted with Traxxas sliders
Maobs on HPI wheels
27 turn/brushless
MTronik Eco20/Mamba 25
2100mAh LiPo
M11 radio with Spektrum
Hitec 5645 servo(s)
HPI Baja Bug body
I think I have covered most bases. I will likely do a little more brazing tonight. If I get further I will post a few more pics tomorrow.
CB
Old 10-23-2006, 05:40 PM   #6
you using safety silv?
Turboduck01 is offline   Reply With Quote
Old 10-23-2006, 06:21 PM   #7
All right sounds like a deal. Now I have to build I solid axle truck. All i have is an indie and a micro.
Old 10-23-2006, 10:28 PM   #8
I am using flux coated brazing rod (bronze based). Likely a little tougher to work with but it is cheap and makes a strong joint. I use MAPP and oxygen to do the welding.
Old 10-24-2006, 01:29 AM   #9
Talking
I think it looks cool
I think you should leve the body off and have a staight tuber coz it looks sick
Shane
Rockmuncher is offline   Reply With Quote
Old 10-24-2006, 08:47 AM   #10
I realized after that I incorrectly said I was going to use a bug body. My plans are actually to leave the body off and just put a couple side panels and a hood on it. The bug body will be used on another project. I hope to get a little more done on the tuber tonight. If I do I'll throw a few more pics up tomorrow.
CB
Old 10-24-2006, 10:19 AM   #11
sounds kool true tuber frame.
Old 10-24-2006, 10:03 PM   #12
Well I worked a little more on my creation and here is where I am at now. You can see some design queues from several different tubers on the forum.
CB
Old 10-24-2006, 11:35 PM   #13
Ya that thing looks pretty cool I cant wait to see it in action.
Old 10-26-2006, 12:34 PM   #14
any updates?
Old 10-27-2006, 12:26 AM   #15
Gettin’ back on the horse
good idea with the bars for the hood coming up so you have shock protection. can keep that thing real low i bet. lets see it in action!
TURTLE is offline   Reply With Quote
Old 10-27-2006, 12:40 AM   #16
I like where your going with that.
Old 10-27-2006, 06:01 AM   #17
Talking
Looks great
Shane
Old 10-28-2006, 08:39 PM   #18
sweet
Blaze is offline   Reply With Quote
Old 11-07-2006, 03:41 PM   #19
Well, I have managed to get more done on my crawler. Talk about a learning experience. I got the suspension somewhat sorted and mounted up and have mocked up the tranny as well. On the to do list:
1: Get softer springs for the shocks.
2: Make new upper mount plates that are flat instead of bent 90 degrees so I can get the links more parallel and lower the ride height a bit.
3: Mod the tranny by dumping the Hydradrive, locking it in a non destructive way (still have the Losi XX and may want to revive it some day) and connecting up the Traxxas sliders.
4: Narrow the rims (should I???) and mount the tires.
5: Clean up the frame, paint, and add a few panels.
6: Mount the electronics and go play!
A couple questions. First, am I the only one that thinks the cab part of the frame is small and looks out of proportion? I guess I could cut it off and redo it but probably won't bother for a while. Also, do you think I really need to narrow the wheels? Any other thoughts/suggestions?
Now for the pics.
Old 11-07-2006, 03:52 PM   #20
~THE SCALE SHOP~
looks very Double J inspired!
STANG KILLA SS is offline   Reply With Quote
