05-06-2007, 04:56 PM | #1 |
RCC Addict Join Date: Mar 2007 Location: Penngrove
| Hybrid Comp/Scale TLT Build
Here are the specs for my latest build: -Hand built carbon fiber chassis and servo/link plates -1/4'' 6061 Aluminum links, tapped 8-32 for long set screws and Revo rod ends -TLT axles, bearings, diffs locked w/JB weld, Blackfoot stub shafts, 4mm locking hexs -Pede trans mounted vertically, bearings, diff locked w/JB weld, 87t spur gear, slipper clutch -55t hand wound integy motor -Blue hotbody shocks with 1.6lb Losi springs and 100wt oil -Pede drive shafts -Proline Moabs with "chcolate block" cut foams -Pede front wheels narrowed 9/16", dyed black with rock rings bolted to 'em -Tazer ESC mounted on rear axle -Hitec 645MG servo -NI-Mh 6-sub C velcro'd to front upper links -Bushwacker body painted dark metallic green and then backed with metallic silver, tinted windows and Losi Lst bumpers |
05-06-2007, 06:56 PM | #2 |
Quarry Creeper Join Date: Apr 2007 Location: .
real carbon fiber or just a sticker?
05-06-2007, 07:57 PM | #3 |
Quarry Creeper Join Date: Mar 2007 Location: hartland wi
thats a darn cool chassis. simple and to the point. i love the body also
05-06-2007, 08:05 PM | #4 |
Pebble Pounder Join Date: Nov 2006 Location: Rye Brook, NY
Agreed. simple. great chassis by the way. |
05-06-2007, 08:19 PM | #5 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
Dang, that thing is really clean looking. Nice job on the cf work. |
05-06-2007, 09:06 PM | #6 |
| More Pics
Thanks for the comments guys, here are some more pics: Oh ya forgot to mention that I am running a 12t pinion and also just swapped two of the springs to 1.8lbs for combating torque flex. |
05-07-2007, 07:08 PM | #7 |
| More specs
-Adjustable wheel base 12.25 - 12.75" -Track width 10.25" -Adjustable ground clearance 3 - 3.25" -Adjustable pinion angle (changes w/ wheel base) Just got a blue Aluminum Hi tec steering horn from my hobby shop today. Was also thinking about getting a buggy or s truck body for more fender clearance. I designed the chasis in AutoCAD Inventor and have full measured drawings of the chassis and link plates, etc. PM me if you are interested. Last edited by Mad4Rnr; 05-07-2007 at 10:46 PM. |
05-07-2007, 07:17 PM | #8 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
great lookin rig.clean. |
05-07-2007, 08:51 PM | #9 |
Rock Stacker Join Date: Aug 2006 Location: Portland
05-07-2007, 09:06 PM | #10 |
Quarry Creeper Join Date: Jun 2005 Location: quarryville
what did you do to the yokes coming out of the tlt axles that you can just conect them to the shafts ??? |
05-07-2007, 09:13 PM | #11 |
What I did is took my dremel, and notched out the otherside to make it have a notch for the screw to screw into and stay in place
05-07-2007, 11:37 PM | #12 |
Quarry Creeper Join Date: Jan 2007 Location: 2 miles from nowhere MO.
Very clean |
05-07-2007, 11:45 PM | #13 |
Then take a chunk of heat shrink to cover the yolk screws so they stay in place :P Just a idea?? lol |
05-08-2007, 12:12 AM | #14 |
| You have to grind off the protruding protion of the traxxas metal yoke. That way you have enough shaft in the yoke to tighten the set screw. I think it is made of stainless so a bench grind and some nice pliers help.
05-08-2007, 12:31 AM | #15 | |
Heat shrink is for wires, lock-tite is for threads! The ultimate fix is to drill a hole through the pinion shaft and use the long set screws (the ones for the pede tranny output shafts) | |
05-08-2007, 12:33 AM | #16 |
05-08-2007, 12:36 AM | #17 |
No I don't. I was looking to "download" one but its such a big file for dial up..
05-09-2007, 07:04 PM | #18 |
05-10-2007, 11:46 AM | #19 |
ahh that really sucks.. My hard drive crashed last year.. I lost everything.. Okay, Thanks |
05-10-2007, 12:03 PM | #20 |
Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
That chassis is the poop, simple and to the point. Nice rig.
