Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Female Trouble Maker!! My TM4 Build Dubbed "JADE"
Old 07-31-2007, 11:21 AM   #1
TJ_Shunk's Avatar
Default Female Trouble Maker!! My TM4 Build Dubbed "JADE"
Ok, I have been slacking on starting this build so I apologize Paul.
I will get my pictures posted tonight of the build up but here is the start.
What I am working with...
TM4 Chassis w/full skid
PaulEZK Servo/Link mounts F/R
TLT Axles
JP Customs Steering Knuckles
Fat-Rock Axle C's
Hitec 645MG servo
Aluminum Servo horn
Axiom 55 Turn motor
12T Pinion gear
84T Spur Gear
Pede Tranny
High Clearence Delrin Rear lowers
Traxxas Turnbuckles for Front Lowers
Traxxas Turnbuckles for F/R Uppers
RC4WD Narrow Alum Beadlocks
ProLine Moab Tires
T/E Maxx Yokes and Drive Shafts
Tekin Rebel2 ECS
Trinity 2 Channel Radio and Reciever
4" Hot Bodies aluminum threaded shock
On the Order List
CVD's For the Front
RC4WD Strait Axle Adaptors and Strait Axle Shafts
G-Made Wideners
Replacement Lowers from Finish-Line RC
My initial thoughts on the chassis from sight...
Crisp looking chassis that is nicely designed and made. I thought that it could used one more hole in the bottom corner of the chassis to flush mount the lower links, but I understand why Paul didn't put them there with the full skid that he made to go with it.
I believe that the upper shock mount holes are a little too high and forward on the chassis, but that is still left to be determined after I get it all set up.
The chassis is a little larger then my SW3 chassis and a lot more closser in size to the SW2 Chassis. I think this would be a sweet chassis to build a super off, but I don't have a super to tear apart to try it with. I will give more specs as to weight in shocks, wheels, and such after the initial set up.
TJ_Shunk is offline   Reply With Quote
Old 07-31-2007, 11:26 AM   #2
now you know you're gonna get flamed for all words and no pictures
Defender is offline   Reply With Quote
Old 07-31-2007, 11:50 AM   #3
Reads good. I'll check back later tonight for some pictures. :-)
PaulEZK is offline   Reply With Quote
Old 07-31-2007, 11:51 AM   #4
Adilynsdad too!
braceysdad's Avatar
I really like that color, looks great
braceysdad is offline   Reply With Quote
Old 07-31-2007, 01:32 PM   #5
TJ_Shunk's Avatar
Yeah I know, but I had to do something to get myself motivated on this build thread
Old 08-01-2007, 06:46 AM   #6
I lost my vendor privileges
sounds good.
clodstall is offline   Reply With Quote
Old 08-01-2007, 07:13 AM   #7
I thought it looked a little too fey for my tastes.
Cloak is offline   Reply With Quote
Old 08-03-2007, 06:56 AM   #8
TJ_Shunk's Avatar
All Right, Until I can figure out my website and posting pictures for linking, this is where I sit so far. I am waiting for the Diff Yokes, upper link mounts to put it all together... I thought I had stuff to make them, but I was wrong.. Opps.
Old 08-03-2007, 08:57 AM   #9
Looking good dude.. :-)
Old 08-03-2007, 11:04 AM   #10
FrankyRizzo's Avatar
I really like those upper link mounts.
FrankyRizzo is offline   Reply With Quote
Old 08-03-2007, 11:16 AM   #11
Too bad he doesn't have anymore...
Old 08-03-2007, 12:34 PM   #12
The 10th is my machine shop date.. I will have tons of link mounts and 10 TM4s.
I will be selling the link mounts for $20 shipped a set.
Old 08-03-2007, 01:29 PM   #13
TJ_Shunk's Avatar
What's funny about those link/servo mounts is that I cut my rear BENDER link mounts in the exact same shape. When I saw these I was all like, that looks familiar.
Old 08-03-2007, 02:20 PM   #14
Really..
Old 08-03-2007, 02:36 PM   #15
TJ_Shunk's Avatar
Yep... Bender has it on video here... He zoomed in on the rear servo/link plate
http://video.google.com/videoplay?do...61646083104534
Old 08-03-2007, 03:31 PM   #16
I can't view videos here.. I'll check it out when I get home.
I got the idea of my mount from two things though, one was a picture of a bender link mount chopped up to bits and pieces, and two was the idea of less material = less weight(simple right), so thats what I came up with.
Old 08-04-2007, 03:21 PM   #17
TJ_Shunk's Avatar
I like the design paul.. Yours is way cleaner then mine was.
Old 08-05-2007, 02:55 PM   #18
Just to let you know, its OK to have weight at the axles...
I like these link too, Im using them on my new scaler K5!
John
KRAWLR4life is offline   Reply With Quote
Old 08-26-2007, 03:26 PM   #19
TJ_Shunk's Avatar
Default *update*
Well it is about time I got an update on this Chassis.
The Budget fell short for now but I have got it put together and Running finally.
We are missing the wideners, and a set of Hot Bodies shocks. It will also be recieving a set of CVD's for the front and the rear Axle lockouts from RC4WD as my wife says that her rig will have all the goodies that mine does now.
Currently I have a set of BENDER's HC links in the rear and just a set of strait turnbuckles in the front. I also used the stock TLT shocks with 10W oil in them as well as the springs from a plain old US Government clicky pen. The torque twist needs to be delt with and it only has like an inch and a hlaf travel, but hey it's a start.
I will first talk about the performance and then pics and a short video will be up.
We took the rig out to a new crawling location called "The Fort". It is what looks to be really grippy rock, but it really is like trying to climb sand. It has a lot of v notches and ledges.
With the current set-up, it is low-slung and so it sidehills pretty good. Even for the chassis being a little large, it is quite nimble on the rocks and ledges. I expected it to be kind of a pig and get hung up on everything, but it got hung up in the same places my SW3 did. As for the location of the link mounts on the chassis, I would/will drill a few more holes further up the chassi plates for the upper links as they really are a good emount lower then the mount on the axle. This might be because of how low I have the chassis set up though.
I also thought that the shock mounting locations would be too steep. I was wrong there as well. I have the shocks laid out just like I do on the SW3 and they work great. My wife drove it most of the day and she was plesently impressed with how it drove for what it was set-up like. I agree with her. So far I am pleased with this chassis. I think that it has the potential to be a contender out there. We will find that out as the CO summer series continues and into the fall/winter series as it will be run in those. (after I finish with the mods ) I think PaulEZK did a good job on the design work and I give the chassis 2 . Alright, on to the pics and video
Video
"Right Click and Save as" please
http://www.cheyennetrailcrew.org/mat...s/TM4Test1.wmv
and now the pics.
Old 08-26-2007, 04:50 PM   #20
Talking
The TM4 is looking great.
It looks really big when its alone but when you see it put together it looks much smaller.
Shane
Rockmuncher is offline   Reply With Quote
