11-02-2007, 02:32 AM | #1 |
Rock Crawler Join Date: Nov 2005 Location: Livermore
| My SW3 Now with Dig
Well I have tried to hold out as long as i could but at our last comp it became apparent that if you are not running dig you are at a disadvantage. I still was able to sneak away with the win but only by two points. With this stiff of competition I felt it was time for Dig. I Placed my order with RCP Crawlers for the R2D trany and received it the next day. In fact everything on my crawler can be purchased at RCP Crawlers. With a little searching here on the form i was able to get some great ideas form others that have put one of these R2D tranys in there crawlers. The R2D was a pretty easy install into my SW3. I only had to drill two holes in the side plate to mount the servo to operate the dig. I opted to run a 5955 servo for my dig. It is probably over kill but what the heck. Well enough talk here are some pics. Before: After: Last edited by 51504rock; 11-02-2007 at 02:40 AM. |
11-02-2007, 02:47 AM | #2 |
Rock Crawler Join Date: Sep 2004 Location: South Orange County
looks mean very competitive setup |
11-02-2007, 03:06 AM | #3 |
11-02-2007, 05:31 AM | #4 |
RCC Addict Join Date: Oct 2005 Location: rite here all along
oops, sorry big D, forgot to call you back, call you when I get off work tonight, now all you need to do is mod the radio with the 3 position switch and your in there............................ .....me to so I can get the LYNX 3D out of mine Last edited by halfcab; 11-02-2007 at 05:34 AM. |
11-02-2007, 08:38 AM | #5 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
I've always held a high respect for you when you beating us all without dig. that last comp at Folsom ( I wasn't there ) was pretty close, and those courses looked pretty tight. Now you will have to use 2 hands to beat us at Moonrocks |
11-02-2007, 09:28 AM | #6 |
Looking good Dustin I like the way you mounted the dig servo, and 333oz.........you won't have any problems with the dig hanging up |
11-02-2007, 10:35 AM | #7 |
RCC Addict Join Date: Mar 2005 Location: MESA, AZ.
I opted to run a 5955 servo for my dig. It is probably over kill but what the heck. WOW! I thought I was over killing my dig with a Hitec 645. Nice Rig. That Novak Brushless has a lot of power. I ran one last year. Be careful with it on the R2D gears. Good luck with the new dig setup. Rick- |
11-02-2007, 02:12 PM | #8 |
Thanks For the complements. I did this DX3 toggle Switch Mod, Thanks rkrawler DX3 toggle switch installation So far i am very happy with this set up. With the 5955 servo i have had no problems with the dig engaging or disengaging. I really like this setup because i can lock the rear tires or let them free wheel. |
11-02-2007, 05:43 PM | #9 | |
11-02-2007, 06:12 PM | #10 | |
| Yeah they do! Quote:
I gotta do this! | |
11-02-2007, 11:47 PM | #11 |
11-02-2007, 11:49 PM | #12 | |
Yea the DX3 Mod works great and very easy to do. I like it for working my winch line on my scaler too | |
11-03-2007, 03:07 AM | #13 |
Rock Stacker Join Date: Sep 2007 Location: Seattle
Awesome! That's very similar to what I am working on building right now... It's good to see that the Goat fits in the SW3 without any major problems. What steering servo are you using, and are you running a seperate BEC in there? If not, do you find the system has enough power for the servos without it? ((I am planning to use a JR 8711 and a dig servo in mine (not sure what size yet), but didn't want to fry anything/loose servo power.)) Cheers |
11-03-2007, 03:19 AM | #14 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
So how exactly dose the DX3 mod work with the R2D do you keep the switch locked to one side for drive then middle is free wheel then all the way is brakes or what? Can you explain this a little better.....
11-03-2007, 11:11 AM | #15 | |
11-03-2007, 11:13 AM | #16 | |
11-03-2007, 11:14 AM | #17 |
| The way you just explained it is exactly how it works. |
11-03-2007, 11:41 PM | #18 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Very nice. Do you notice the weight of the extra servo on the chassis while crawling? I'm slowly working away on my dig set-up. |
11-04-2007, 01:06 AM | #19 |
11-04-2007, 01:47 AM | #20 |
| Thanks Brad. Yes I do notice the weight of the servo. But the little extra weight has been a good trade off for dig. I am thinking about trying a mini servo because i think the 5955 is way more than needed. I have been beating the snot out of this set up this weekend and have yet to have a problem. Just make sure you have your End points adjusted and your linkage set up with out any binding. I have put this set up in a bind were i stalled the motor and the everything held up to the goat system. so far so good |
