Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Mounting Big Bore's to TXT-1
Old 09-10-2005, 07:37 AM   #1
Default Mounting Big Bore's to TXT-1
Hey guys
I tried doing a search on this and could'nt come up with much.
How do you mount your Traxxas Big Bore Shocks to your TXT-1?
I just bought 4 but they havent arrived yet, I'm not sure if they fit the pivot balls like the stock one's do or if I have to buy some mounting screws or what ever?
Part Numbers and Descriptions would be good.
Cheers, Dave
4X4XFAR is offline   Reply With Quote
Old 09-10-2005, 03:14 PM   #2
I found these screws, still not sure how they're mounted?
http://rchobbies.com.au/store/produc...c2c81a4e33d8c4
Old 09-10-2005, 07:55 PM   #3
FrankyRizzo's Avatar
You will need the plastic stand offs that come with them for the cap part of the shock. I would also leave the bolt a little loose to accomodate pivot.
FrankyRizzo is offline   Reply With Quote
Old 09-10-2005, 09:23 PM   #4
I use shock spacers for the cap part with M4 screws and nuts and for the bottom pivot ends I used 2 con washers with M4 screws and nuts. you can get them either at RC4wd.com or neweraracing.com.
Kev808 is offline   Reply With Quote
Old 09-10-2005, 11:20 PM   #5
v33
you can use tubing sandwhich between 2 washers. well thats what i plan to do ... need to look for the tubing first.
v33 is offline   Reply With Quote
Old 09-11-2005, 06:24 AM   #6
Stand Offs?
Old 09-11-2005, 09:11 AM   #7
v33
Originally Posted by 4X4XFAR
Stand Offs?
well if you bought the 8pc set, you should have those. its the plastic spacer that you insert on the cap of the shock, then screw it on the chassis.
those screws you posted wont work, you need a 6mm tube.
Old 09-11-2005, 10:26 AM   #8
Bahhh, I don't understand anything your on about, I'll have to wait till they get here and then bang em on with Gaffa Tape and Wire Ties!
