10-21-2004, 01:47 AM | #1 |
Pebble Pounder Join Date: Jul 2004 Location: San Jose, Ca
| what is the best gear reduction>???and what ratio?
I am looking for a geaR reduction, what would be the best to go with?? I know the gd-600 comes with a 3 to 1 ratio and a 2 to 1 ratio, what would be better?? also can someone link to a good place to buy... Thanks... |
10-21-2004, 08:58 AM | #2 |
Rock Crawler Join Date: Jan 2004 Location: Round Rock, TX
| Re: what is the best gear reduction>???and what ratio?
The GD comes with an 18t pinion, which gives it a 2:5.1 out of the box. I bought a 13t to go along with it, but after running the stock pinion (with a 9t on the other end), I think that'd be to slow. R/C Unlimited on Union and Camden has (had) them for $13 (same as Tower). It was listed under the wrong part number though. Ask for a GS-600. Or, give them the Tower part number, LXSL79. |
10-21-2004, 09:26 AM | #3 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
The slower the better... i found that the GD600 was very easy to mount and centered the motor almost perfectly. i have found out that with the 3:1, my rig will almost not free roll downhill once you stop... its kinda nice. there are a bunch out there but this one seems to be the most popular... with the most info on line too,....
10-21-2004, 10:39 AM | #4 |
how owuld the motor mount work?? from a double to single motor mount?? do I have to make one?? if, so what did u guys do or use to make one??? so best thing to do is to leave the the reduction alone and play with different pinions on the motor?? what combo would I have to run to get a 3:1 ratio?? thanks again guys... |
10-21-2004, 10:59 AM | #5 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
Your can go the mammoth route as well. But all the answer are you just search around and you'll find them. I'm running a GD600 @ 2.5 with a 9t on the motor. I've run it with a lathe motor and it was pretty slow I changed to a 27t and I now have wheel speed but it doesn't crawl as well. I might go to 3.0:1 with the 27t. But my motor is making funny noises all of a sudden. So we'll see
10-21-2004, 12:02 PM | #6 | |
| Re: what is the best gear reduction>???and what ratio? Quote:
I posted a chart >>in this thread<< that has a gearing chart. Here it is as well... Code: GD redux: 2.5:1 (18t 48p pinion on motor - stock as supplied from Great Planes) Output shaft pinion: tranny ratio: final redux: 15t 34 (stock) 85 14t 36.4 91 13t 39.2 98 12t 42.5 106.3 11t 46.3 115.6 10t 51 127.5 9t 56.6 141.5 GD redux: 3:1 (15t 48p pinion on motor) Output shaft pinion: tranny ratio: final redux: 15t 34 (stock) 102 14t 36.4 109.2 13t 39.2 117.6 12t 42.5 127.5 11t 46.3 139 10t 51 153 9t 56.6 170 GD redux: 3.5:1 (13t 48p pinion on motor) Output shaft pinion: tranny ratio: final redux: 15t 34 (stock) 119 14t 36.4 127.4 13t 39.2 137.2 12t 42.5 149 11t 46.3 162 10t 51 179 9t 56.6 198 GD redux: 3.8:1 (12t 48p pinion on motor) Output shaft pinion: tranny ratio: final redux: 15t 34 (stock) 129.2 14t 36.4 138.3 13t 39.2 149 12t 42.5 161.5 11t 46.3 176 10t 51 194 9t 56.6 215.1 Last edited by cheapjeep2; 10-27-2005 at 07:50 AM. | |
10-21-2004, 03:14 PM | #7 |
MODERATOR™ Join Date: Jul 2004 Location: Ohio
I went with the 129.2:1 ratio. Works quite nicely, slow, torquey, and just enough wheel speed left over. It's my 3rd, and final gear ratio change. |
10-21-2004, 04:36 PM | #8 |
Quarry Creeper Join Date: Aug 2004 Location: Guntersville
Can someone give me the final ratio with 20t 48p & 9t 32p. THANKS |
10-21-2004, 07:23 PM | #9 |
The spur on the GD is 46t, so 46/20=2.3:1 We know a 9t pinion on the the tranny gives us 56.6:1, so 56.6x2.3=130.18. |
10-21-2004, 07:49 PM | #10 |
Thanks
10-22-2004, 10:20 AM | #11 |
20K Club Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
I tired searching aroung but couldn't really find anything productive about the inline reduction. I kept running into people who would say it but then go on to talking about a 600 or mamoth. Anyone use these around here, if so why or why not?
10-22-2004, 10:44 AM | #12 |
You mean the MP-Jet worm reduction? Looks cool, but needs more mods to make it work. Something about an adapter plate. Plus, I think's it harder to find than the GD, even the Mammoth box. I don't know to much about it, but I don't think you can adjust internal ratios with it. It's set at 3.8:1, IIRC.
10-24-2004, 06:29 PM | #13 |
Newbie Join Date: Sep 2004 Location: Baltimore,MD
I am starting to build up my stock TXT, Going to do the standard stuff , and want to set it up with one of these reductions.Now the big question , I would like to run it with a Magnectic mayhem motor , which ould it be.Standard rotation or reverse rotation?
10-24-2004, 10:20 PM | #14 |
With a GD 600 and the motor in the back, it's normal rotation.
10-26-2004, 06:08 PM | #15 |
Motor in the back?????? Do I have to turn the tranny around? What about leaving it stock? |
10-26-2004, 07:13 PM | #16 | |||
10-27-2004, 09:01 PM | #17 |
So if I were to just replace both stock motors , I would have to replace them with reversed motors?
