Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: shims?
Old 03-26-2010, 05:19 AM   #1
Default shims?
are there any shims required on gear mesh for txt/jugg 2 axles. thanks in advance.
aircooled67 is offline   Reply With Quote
Old 03-26-2010, 03:03 PM   #2
Not according to TXT-1 manual, but I used shims when I built my axles.
When I installed the differential with long and short shafts, I placed thin shims on opposite sides of the diff to take up any loose play. Tamiya tells you to place a washer on each end of the axle shaft, next to the c clip. I was able to move the diff side to side and wanted to eliminate that. Make sure you do not shim too tight just enough to take up the excess play.
I also used a shim on the top right angle gears to keep the gears mesh consistant. Without the shim I found that the mesh was not consistant when turning by hand. I would imagine that in time as the gears wore, this movement can lead to excessive wear. I also used red locktite to hold the gear onto the splined shaft during assembly. I made sure that the gears turned freely without binding up.
mavrim is offline   Reply With Quote
