Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: Revo shafts
Old 12-21-2004, 06:35 AM   #1
Location: On my acre and a half of Gods Country. Prosper, TX
Default Revo shafts
I want to lengthen the links on my new TXT this weekend or next week. I saw something about using the Revo shafts when this is done, but somewhere I thought I saw something about using the Revo axle shafts, not the driveshafts.
Does anyone have any info on this? and if you have the part #'s that would be even better.
Mark
T-Man is offline   Reply With Quote
Old 12-21-2004, 08:56 AM   #2
Diggin' the new SCX10 II!
badger's Avatar
Default Re: Revo shafts
Here you go T-man. All the info you want on Revo's.
http://www.rccrawler.com/postt2497.html
badger is offline   Reply With Quote
Old 12-21-2004, 10:14 AM   #3
Thanks Badger.
Is all I need the " 5451 --- Traxxas Drive Shaft Assy Revo " ?
That is all I see in the link, but I was also told that I might need all these other parts.
5450 - get 1 pkg ---- Traxxas Half Shaft Set L&R Revo ---
5452 - get 1 pkg ---- Traxxas U-Joints Drive Shaft Revo ---
5455 - get 2 pkgs ---- Traxxas Center Front and rear half shafts Revo ---
Old 12-21-2004, 10:25 AM   #4
yep thats it. you can the parts seperately with those other #'s or complete with the #5451. just remove the pin the holds the steel stub axle in and pull the stub out. then use that yoke on your tranny with the mod Badger did.
its pretty easy as long as your WB is long enough.
rckjeep is offline   Reply With Quote
Old 12-21-2004, 11:42 AM   #5
I just ordered 2 packages of 5451 for $7 a piece.
I looked at the description of each while at the LHS and found out that 5451 was the complete set-up, and the others were all pieces.
BTW, these are Axle shafts, not the drive shafts. That was one of the questions I had.
Old 12-21-2004, 11:57 AM   #6
P/N 5451 comes with these yokes
Here's a pic of the completed driveshafts.
This is a close up of the yoke INCLUDED with P/N 5451
It works with a TXT tranny from what I understand
The OTHER yoke is P/N 5458. Here's a pic
It works with a emaxx tranny b/c that is what I used.
Hope this clarifies things.
cman_1500w is offline   Reply With Quote
Old 12-21-2004, 01:32 PM   #7
Did you make any mods to fit the emaxx. I haven't been able to get them to fit without modding.
Old 12-21-2004, 09:44 PM   #8
rckjeep, I had to drill the yoke to the size of the tranny's output and grind the end down flat. Takes 2minutes tops.
