04-01-2007, 06:57 AM | #21 |
REST IN ALOHA CHIP Join Date: Nov 2005 Location: *
| just a hunch but try running it using a receiver pack to the receiver(5cells) and then try just running it off of six cells it might not be totally fried.......maybe just the BEC this tends to happen with these ESC's that way you'll know if its still salvagable at least.
04-20-2007, 07:15 AM | #22 |
Newbie Join Date: Nov 2006 Location: Duluth
| I finally got the slip rear clutch up and running. It could use a little stronger servo or a spring with less spring rate. I haven’t really tested it yet since I still have to get my ESC hooked up. Hopefully I’ll have more feed back next week. Also a little shorter spring would help so I would have a true neutral. I don’t know it that is really necessary to have a true neutral but maybe have it a brake instead when the clutch separate. http://s158.photobucket.com/albums/t...t=100_1494.flv |
04-21-2007, 09:36 AM | #23 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
Comp tomorrow (4-22) out at Taylors Falls. Get that thing fixed and on the rocks!! MNRCRC Spring Fling 07 Season opener Last edited by freetimecrawler; 04-21-2007 at 09:39 AM. |
04-23-2007, 11:22 AM | #24 |
| I’m trying freetimecrawler… As you can see from the video that I posted right before your comment I got the clutch working and last night I was able to hook up the ESC. I’ll try to make your next crawl (May 6th) if I’m in town. |
