02-21-2005, 08:20 PM | #1 |
Quarry Creeper Join Date: Oct 2004 Location: Canada eh!
| Finally got some stuff done!
Well i are u can read i finally got some stuff done that i have be waiting to do, not that we got show up here in canada and now most of its gone, not enuff for snowmobileing, I got back to the TXT-1, Got the BFT's on got the 4ws all up and running and she runs like a champ, well not that we got her running good she needs a sweet body! so take a look and let me know what u think! thanks With out BFT's and just stock TXT-1 tires http://www.rcpics.net/view_single.php?medid=50056 and http://www.rcpics.net/view_single.php?medid=50055 And with the BFT's http://www.rcpics.net/view_single.php?medid=50058 and http://www.rcpics.net/view_single.php?medid=50057 if u can see the other sidfe u can see i was too lazy to change all the wheels for the pics! lmao now just waiting on weather to clean up to go crawling, also i picked up a set of lclod axels and im gonna make a clod crawler and my brother-in-law is gonna make me a chassy and links in his machine shop. If u guys want ill show u pics as that comes along! |
02-21-2005, 08:38 PM | #2 |
Rock Stacker Join Date: Feb 2005 Location: Houston
Cool truck i wish i had access to a machine shop i have cad and everything but no machines :? lol i probly have the wrong cad anyway
02-21-2005, 09:22 PM | #3 |
Rock Stacker Join Date: Jan 2005 Location: Chattanooga
Looks like a good start man! ...so when you going to cut the lower chassis for clearance?I do have one qwestion when I was starting out and I had that setup on the links with out my maxx axles I only had partial movement in the links travle,have you experienced this? the stock shaft only have about a centimeter of travle when I moved my links up like that the shaft would get the the end of travle before complet articulation?I do have to say love the body choice,I'm a jeep guy!(incase you don't know they have disc. the cj8 and the rubi bodies from proline so buy up a cuple if you find them!)
02-22-2005, 12:17 AM | #4 | |
Quarry Creeper Join Date: Nov 2004 Location: Frayed ends of sanity
GET YOU AN EB(early bronco) http://img141.exs.cx/img141/3664/crazyhorse1di.jpg | |
02-22-2005, 01:56 PM | #5 |
well i thought about cutting the chassy last night but i dont hink im going to becz im not into hacking the frame. but if i did and oved the tranny up do i need new drive shafts? and i have had no problems with my shocks! im still undecided on cutting the chassy! let me know if u do know if i have to get onger drive shafts or make some up! thanks |
02-22-2005, 02:26 PM | #6 | |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
02-22-2005, 05:12 PM | #7 |
ya but will i have to make longer dirve shafts or what ?
02-22-2005, 07:00 PM | #8 | |
02-22-2005, 07:35 PM | #9 |
well sounds good, I got the turck all pulled apart to cut theframe and the tranny and i was wondering i saw some guys with one motor in there turck is that better? and how do u change it over to 1? |
02-24-2005, 08:54 PM | #10 |
| Oooook not sure what to do about .....
well i hacked the frame today, rised the tranny, got my revo shafts on and everything is all up and tog ether, but electrons(doesnt matter right now) i was loking bec i only have 2 screws holding the tranny and if u press left or right at the bottom of the tranny case it moves the tranny little back and forth, i havent got the truck up and runing yet but i was wondering is anyone else had this problem, or Know what to do to hole the tranny in place, ill have some pics up soon like tomorrow, wheel bace is now 15" by the way, well let me know please! |
02-24-2005, 09:02 PM | #11 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
Why do you keep starting new threads? Use one of your previous threads to ask this question. I am closing it so you can copy the text then I will delete this. Also, if you search this as been answered many times. In fact I think it was answered in your cutting txt frame thread. EDIT By RCKJEEP, I've merged the two threads. airranger, lets try to keep new threads to a minimum. Last edited by rckjeep; 02-24-2005 at 11:48 PM. |
02-25-2005, 01:53 PM | #12 |
ok sorry, i pulled the stock shock set up off the truck and im gonna try to mount the shocks different so ill let u know what i make out with.
02-26-2005, 07:10 PM | #13 |
| Question about this motor!
Ok i did do som searching and came up withs omething but they never talked about the TXT-1 just the cod, Ok i have a TXT-1 some of u know and i want to put Magnetic mayhem's in it, i want the battery up front so my old motors i just shitched the + and - just so i could have batt up front, i see some guys 180 the tranny, what if i left the tranny in the same direction it woild do the same as tuning the tranny right?? I want to know what one i would need for the TXT-1? The Magntic Mayhem's or the Magntic Mayhem Reverse??? ok so just to let u know my trannys the same way and my axes are switched around so what motors will i need revers or normal??? thanks p.s. i just dont want to order the wrong motors! |
02-27-2005, 01:59 PM | #14 |
Quarry Creeper Join Date: Mar 2004 Location: Central NY
With your axles switched you effectively rotated the tranny, so you need the reverse MM.
02-27-2005, 03:51 PM | #15 |
My buddies got a rev MM he doesn't need $20 and it's yours.
02-27-2005, 04:19 PM | #16 |
well if hes got 2 ill take them unless some one know whow to put one motor on a TXT-1
02-27-2005, 06:04 PM | #17 | |
Rock Stacker Join Date: Feb 2005 Location: Rachel Rays Bed
02-27-2005, 09:57 PM | #18 | |
02-27-2005, 09:57 PM | #19 | |
03-01-2005, 02:38 PM | #20 |
| New Question!
ok a quick quest about motors and stuff, ok i finally got my truck all back together after putting revo shafts and chopping the frame and i decied to keep one motor in it a Titan (i know i know i need a better motor) with a 13t pinion on it, drove it around in the hoes becz its snowing again and when i left the roomand came back it smelt like burn motor, lol is it that the titan is sooooo crap it cant run the truck with out 2 motors or would the truck be fine if i put one Magnetic mayhem in it? or will i need 2? and i have learned alot of people on here cry! |
