08-12-2007, 10:05 PM | #1 |
Pebble Pounder Join Date: Oct 2005 Location: Noblesville , IN
| Help me with part numbers please!
What part numbers are needed to build TXT axles?
08-13-2007, 03:42 AM | #2 |
Rock Crawler Join Date: Apr 2007 Location: Hawaii
Most of the parts are listed in this thread, it's spread out a little but most of it is on the middle of page 2. are Jugg 2 axles ok for crawling? It was for a Jugg axle upgrade upgrade kit Tamiya discontinued so you'll still need what was in the kit; 2 axle housing trees, upper shafts,upper axle gear sets, screws, nuts, bushings(or bearings), and e-clips. My suggestion to you is to just buy a complete axle assembly off ebay or qualify here on this forum so you can use the for sale/ wanted ads to get them. Here's how to qualify: Classifieds Section If you still want the part numbers for the stuff in the kit just post and I'll help you find them. |
08-13-2007, 08:22 AM | #3 |
| Thanks for the help
Thank you for your help. |
08-13-2007, 11:36 AM | #4 |
No problem, do you still want help with the other part numbers? I should have told you to post if you did or didn't.
08-13-2007, 02:48 PM | #5 |
Newbie Join Date: Jan 2006 Location: Redmond Oregon (High Desert)
08-13-2007, 02:59 PM | #6 |
But if your good with a grinder you can grind these down ( http://www.tamiyausa.com/product/ite...uct-id=9805814 ) and they will work. After all you are jb welding everything anyways.
08-14-2007, 09:02 PM | #7 |
What are the top gear #s? Other than that I'm good. I think. Thanks for your help. Dave |
08-14-2007, 10:14 PM | #8 |
The upper axles gears are: pn# 5495023 x 2 MR16 drive gears(just saw it is discontinued)(sold individually) pn# 9805814 x 1 MR17,MR18 bevel gears(package 2 pcs each) pn# 9805813 x 1 MR10 bevel gear shaft short(package 2 pcs) pn# 9465589 x 1 Screw bag G(contains 2 MG2 bevel gear shaft long)(you can also get this at Tower Hobbies) Here's a link to Tamiya USA TXT page for those parts: http://www.tamiyausa.com/product/rcp...s&kit_id=58280 bearings for the top gear shafts: 2- 5mm x 8 x 2.5 6- 5 x 11 x 4 4- 6 x 11 x 4 (these are a special size bearing that are harder to find)(pn# 9805802 contains 2 bearings ea) I think that's everything... |
08-15-2007, 06:03 AM | #9 |
Thanks for the help hawnmt.
08-16-2007, 06:20 PM | #10 | |
Rock Crawler Join Date: Jul 2005 Location: Central Coast
Do any of you guys know of any other type of gear (or almost anything really) that has the same spline count as the axles? I was thinking maybe I could just braze the splined gear inside the diff even if the teeth don't mesh together. | |
08-16-2007, 08:32 PM | #11 | |
Those are the TXTs top axle bevel gears. I was going to ask Bad Habit about how he did the mod too. Those gears are pretty big so I know it would take a lot of grinding to get them to fit inside the diff housing but I think he used them becauce they do have the same spline as the axles. I think it would work to either weld, JB weld , or braze them to the diff housing without using the star shaft or spider gears. | |
